Microsoft's Surface
xjasonz
getting frustrated with the taskbar..when is MS gonna fix it...it gets annoying when using the surface without the kb...other than that, i got no complains about it..
samloi
anyone knows if VM works well for the surface pro3? I am planning to use the surface pro3 as a backup for my work laptop. But the industrial programs i using are designed for win7 only...not too sure if VM runs all win7 programs and drivers
purpleberry
I don't see why not. Apart from it's physical appearance, it works just like any other laptop. The only slight problem would be to downgrade win 8 to 7. You might want to check with their technical support for confirmation if win 7 could support all the necessary drivers for SP3.
mudxblood
Anyone got the same problem as me? When my SP3 fan tends to kick in, it will gets hot behind. This is normal. However, the magnesium alloy behind will starts to discolour.:s22: Looks the build quality isnt that good. The edges surrounding my SP3 also begins to peel off.
Fallingrain
I got paste skin at the back and side. So this is not a issue for me.
purpleberry
You might want to call Microsoft customer service to hear what they say. If you're lucky, you can get a new one.
eyz
if the top button of my stylus is not working, i should change the button battery, right?
Syraxius
