Mini ITX Build
tjkjean
Perhaps you can wait for Inwin A1+? Price will increase maybe from $259 to $299 but they now provide 650W gold psu included.
Apart from the psu, any other diff for A1 Plus?
Can't find much info. Any idea eta for SG?
t258jgn
Just ask Corbell to setup & GPGT
MSI Z390I Gaming Edge AC
MSI RTX 2080 Ti Lightning Z
Gskill Trident Z Royal 3600 4x8G / Silver
Raijintek Ophion EVO
Seasonic Focus Plus 850FX (smallest size full modular atx psu)
shadow84
Can get corbell amd ryzen cpu and adata nvme ssd. Complete AMK rig. Lol
tjkjean
Bro, this GPU not 2 slot leh
lifeishard
Based on PCPartpicker, i9 9900 and 2080 TI will draw about 415 watts.
You can run the SF600 platinum and power those components.
Let's be realistic here, with an ITX Build, you won't be doing much overclocking due to airflow issues.
You can even be ambitious and try to fit it into a A4 or Geeek A50/A60. My only recco here is to go with a SFX
psu so you can have the widest variety of cases for your selection. Pick an ITX case that you like and with the SF600, you should not have any problems.
It will run hot or loud, depending on which is your comfort factor, but my 2700x in a Cougar QBX is running at 43 degrees idle, I let the 1080TI run whatever, capped at 75 degrees. However, it is quiet, and works well for gaming purposes.
Total of 4 120mm intake fans and its working out for me.
Was qbx easy to work with? You using SFX or ATX PSU?
Ind1go
Yes, QBX is bigger, but the trade-off is cheap, can use 140mm ATX PSU (but a SFX psu will still be easier to manage), can use AIO and many fan mounting options.
tjkjean
Where selling this cougar qbx? Want to see see
t258jgn
ITX can has 4 DIMMs?
Paisei... Only 2 dimm slots :D
Thermaltake Core P1 TG
Best airflow
gld998
Newegg selling. Go YouTube and see. Local like don't have. SLS go walk walk and tell us. I also tempted to buy one.
Sent from HUAWEI SHT-AL09 using GAGT
tjkjean
Thanks guys for the recommendation...
Some changes along the way on the components...
Here's it!!
Idling temperature..
GPU Side..
CPU Side..
shadow84
Ur top fans seems to be fight for air with gpu, seeing how close it is. 39deg on idle isnt fantasic. Try swapping top fans to intake?
tjkjean
The idling is now ard 35 deg after some cable mgmt.
Not sure what to expect thou for this cpu.
Changing the 2 top fans to intake means no fan for exhaust.. will it be ok?
shadow84
It will escape thru other holes in your case. U can try a stress test and see if the difference is worth it or not. Idle temps dun tell us much.
tjkjean
Hahaha I'm the lazy kind.
Thanks bro. Might try to test test
harharhar
i'm interested in this case, but worried about dust. If you don't mind, after a week or so, can feedback on how must dust enters? and how difficult is it to achieve positive air pressure.
Thanks!
