I just overclocked apu to 1500mhz @ 1.2V & Ram @ 3200mhz.
Temp went 90deg w prime 95 max.
But normal gaming temps hovers below 65degs. E sports games like Dota 2 increase fps about 15-20%.
Haven try OC the cpu. Dunno if my power supply 150W will take it a not. Hah.
90'C is the throttle temperature. So your CPU may be lowering the clock speed to keep within safe temperatures.
So your o/c may not be effective when fully stressed. If you are not troubled by that then no worries! Great result actually!
If you want to test your o/c properly the CPU temperature needs to max out at less than 90'C (example 89'C), so that you know the o/c stays effective all the way.
Though Prime95 usually gave me stable results I usually got stuck playing a game like TF2. My advice is also play a game to confirm stable o/c.
Both CPU Vcore and SOC voltage make a huge difference to temperatures. IIRC 1.2V is a decent SOC voltage. You have not stated CPU Vcore. I think lowering CPU Vcore by tiny amounts is safer over SOC voltage.
150W power supply should be enough. I doubt your system at load will exceed 120W.
Powerful exhaust fans help a lot in cooling. I chanced upon some AVC 6010 fans that max out at 6000RPM each. At 6k RPM they are noisy, but it never touches that in regular use.
Edit: For games CPU clock may not need to be very high. A slightly lowering of CPU freq will reduce heat a lot, and give you a lot of playroom for your memory and GPU clock.
In my case I lowered CPU from 3.5 to 3.4 and that gave me a lot of headroom for o/cing the GPU and memory.
