[Mini OC guide] - EVGA X58 LE
myxpdc
sorry a liitle bit out of topic.
I bought HD5870 vapor x which is ATI.
ATI is for Crossfire
Nvidia for SLI.
Is it right to say that i wiil be stuck with single card since i am unable to to run ATI crossfire on SLI motherboard.
Regards.
DiYuSiShen
i not sure about the evga p55 but i know the evga x58 sli le supports both cfx and sli
OralMaster
thanks for the guide, just overclocked my 920 to 4.0 Ghz
Vcore 1.26V
Vtt +50mV
Vdram 1.65V
thanks ionicle =D
tested with OCCT after many many attempts
Temps and CPU
ColinYip
Getting to 4ghz is a breeze.
Check out the xtreme systems forum for their P55 and X58 mobos.
ionicle88
not impossible to do 4.5GHz but without water cooling please don't try it.
ionicle88
Updated some of the pictures in the first few posts with the features from the S744 bios...
its minor but do check it out.
chewbm
Need some help here.. even on stock, i'm already getting 40 ~ 50 degrees.. Tried reapply thermal paste and resit the heatsink (venom x with sflex-g - push).. still experience the same result..
http://i230.photobucket.com/albums/ee205/chewbm/Computer/RealTempPics.jpg
my current layout as shown (pardon my poor pics, lazy so use my blackberry to take the pics)
http://i230.photobucket.com/albums/ee205/chewbm/Computer/IMG00048-20100219-0852.jpg
anything i can improve on?
Overclock Settings
Frequency Control
CPU Clock Ratio (x 20 )
CPU Host Frequency (Mhz) ( 201 )
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( Auto )
CPU Clock Skew ( Auto )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 100 )
Memory Feature
Memory Control Setting (Enabled )
Memory Frequency ( Auto )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( 8 )
tRCD Setting ( 8)
tRP Setting ( 8 )
tRAS Setting ( 20 )
tRFC Setting ( 59)
Command Rate ( 1T )
Voltage Control
EVGA VDroop Control ( Without VDroop )
CPU VCore ( 1.35v )
CPU VTT Voltage (+50mv)
CPU PLL VCore (1.35v )
DIMM Voltage ( 1.65 )
DIMM DQ Vref ( +0 )
QPI PLL VCore ( auto )
IOH VCore ( auto )
IOH/ICH I/O Voltage (auto )
ICH VCore ( auto)
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Disabled)
CxE Function ( Disabled )
Execute Disable Bit (Disabled )
Virtualization Technology ( Disabled )
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( Auto )
Tried to overclock to 4Ghz.. only last me 5 mins before OCCT stop due to CPU Hot error (93 degrees), sian 1/2.. bo pian, so return everything back to stock 1st..
chewbm
Just bought and applied Noctua NT-H1 thermal paste.. doesnt seems to help with the temp..
any advise..? thanks in advance.. :)
ionicle88
drop your vcore to 1.28750, while keeping the rest intact.. and did you change the temp limit in OCCT before starting the test????
Erm, did you tighten your venomous X?
your idle temps are a bit high for stock honestly.. and i have a feeling it is due to your sitting of your cooler...
chewbm
i was feeling the same thing too, but i have tried to resit the HS thrice, i also tried varying the tightness of the pressure knob, all the same temp... d*mn pek chek.. :s27:
as for the voltage, i cant seem to go below 1.35V, else BSOD upon reboot.. the OCCT temp i set it at 105degrees.. :)
ionicle88
can remind me which chip which stepping and which batch are you using?
