[Mini OC guide] - EVGA X58 LE
ionicle88
yes media player is working fine using stock & oc dummy higher than that it willl flicker follow by the message until the movie end. Using sony vegas 9.0c for video editing. No problem with other format such as blue ray etc source not from video editing.
Regards.
go under cpu settings and disable intel turbo and test again.
should be not enough voltage coz u running @ 4.2GHz.
or alternatively. up vtt to +75mV and vcore to 1.3V then set pll voltage to 1.35V
myxpdc
Ok, i will install the new nvidia driver 1st before proceeding to your advised.
Thanks.
myxpdc
Hi,
install new driver
up vtt to +75mV
vcore to 1.3V
pll voltage ? ( ur refering to QPI PLL or CPU PLL )
Play my AVHD m2t file OK using media player 12.
Do I need to increase the PLL to 1.35v.
BTW, will oc make my computer life spend shorter.
Is my psu good enough to run HD5870 vapor X or shld i wait for fermi.
Nvidia got CUBA good for video editing?
Sori too much question already.
Thks.
ionicle88
Hi,
install new driver
up vtt to +75mV
vcore to 1.3V
Thks.
cpu pll voltage.
there are numerous rigs in this forum that has gone through tons of overclocking and are alive and kicking after 3-4years...
600W i will not recommend you to do crossfire coz the power draw will be too huge for your 600W to take it...
the entire fermi thing... i can only comment and conclude when the product is out. so all the talk now are speculations... CUDA is good along with OpenCL so long as u can find a program that supports it... For trial testing u can download badaboom and try the CUDA out first.
Gforce8
hmmm.. a bit OT but i would like to ask.. i3 530 + EVGA P55 LE can hit 4GHz? :)
ionicle88
waaa.. sure bo.. lol.. so vcore 1.3V should be enough liao? :D ;)
yea...
go google the overclocking of the clarkdale chips...
haven try before but if u wanna let me try one piece.. sure by all means :D
Gforce8
yea...
lol.. cos i am thinking to get this combo or go for AMD.. about the same price but QUAD core.. :s11:
