MoCA Network Setup | Ethernet over TV cable
manyu882
Interested in this. Just need more info on the product. Is this comparable to GoCoax in term of performance? The power adapter will be UK or EU pin?
1) have not tried it... my first time too. It uses maxlinea chip which basically the same as goCoax. And Hitron is a mega company. More reputable than goCoax. If you Google search “Hitron and moca 2.5”, you can see they are in the news on well known news platform.
2) can be in EU or US
Can request the type during MO
weeza77
Pls keep us updated. Any links for further info on specs.
manyu882
hello,
where can i buy this poe for cable at sl...?
thanks.
U referring to filter for MoCA adapters? I Think it’s hard to get it in SG.
Recommended POE for moca is 5 to 1002Mhz pass, 75ohm, at least 40db rejection. To find this specific spec is hard.
But as Long as you can find a pass band that is outside 1125Mhz to 1675Mhz. MoCA signal (D band) will not leak out from our unit.
Borckster
Hi, does the moca adapters you mo come with this poe filter. And, are they 240v with EU two pin plugs.
Borckster
If difficult to find, just disconnect the main coaxial cable from Starhub unless you are on Starhub services using coaxial.
This is a likely outcome. I posted a picture recently of a svc box in house, I think that is where scv enter the house and split in to 4.
manyu882
POE filter is not included in the standard package but I can add it in just for S$5 per piece.
2 pin plug included
Borckster
Or how to use your TV cables for your computer network!
#### STORY #########################################################
I recently switched from Starhub 100Mbps Cable Broadband to ViewQwest 2Gbps Fibre Broadband and with that change I also wanted to solve my annoying WiFi connectivity issues whilst using the actual bandwidth I'm paying for. The only way to get fast internet to my computer in a room that it furthest away from the fibre termination point in the living room was via wired connection.
Unfortunately, my building does not have Ethernet wiring and I'm not really interested in having any cable lying lose between rooms. I haven't made any good experience with PowerLine devices in the past (Ethernet over electrical wiring) and the only other thing I stumbled across was MoCA - which finally solved all my issues and gives me around 950Mbps internet access.
Here is my current setup at home with fibre internet provided by ViewQwest. Starhub is in the diagram as they used to provide me with cable internet and TV.
#### FUNDAMENTALS ###################################################
MoCA stands for 'Multimedia over Coax Alliance'. The technology behind that term allows the distribution of ethernet data over the existing in-home coaxial TV cabling. Simply said, it can convert a Ethernet signal to run over coaxial cables. MoCA networking can co-exist with video data on the same coax cable.
---ethernet-cable-----[MoCA Device]=====coax-cable=====[MoCA Device]-----ethernet-cable---
MoCA version 1.0 was approved in March 2006, MoCA 1.1 in April 2010, MoCA 2.0 in June 2010 and MoCA 2.5 in April 2016. Technical throughput specifications are:
• MoCA 1.0 ---> 100 Mbit/s
• MoCA 1.1 ---> 175 Mbit/s
• MoCA 2.0 ---> 500 Mbit/s
• MoCA 2.0 bonded ---> 1.0 Gbp/s
• MoCA 2.1 ---> 500 Mbit/s
• MoCA 2.1 bonded ---> 1.0 Gbp/s
• MoCA 2.5 ---> 2.5 Gbp/s
MoCA uses frequencies between 500MHz to 1650MHz (dependent on the application). Cable companies typically use frequencies up to 1000MHz to send signals, satellite dishes usually use frequencies above 1000MHz.
#### POE FILTER ######################################################
In order for MoCA to work, a 'Point Of Entry Filter' needs to be installed into the main coax cable before it branches off into different coax outlets of your flat. The cable connection can be found at an entry point into your premises such as a riser cabinet or a cable distribution box within your home.
The filter simply blocks MoCA frequencies going back into your cable providers network (or your neighbours network) and potentially interfering with the network or system elements.
Alternatively, the incoming main coax cable can also be disconnected from your home network if no service is used by the cable provider (just ensure to add a 75 Ohm terminator cap to your coax splitter).
Either ways - one solution is mandatory! For me, Starhub installed the POE filter in the riser cabinet free of cost - the filter used is a 'Soontai LPF-1002M3'.
[Starhub]====>[POE Filter]====>[Home Coax Network]
#### COAX SPLITTER ###################################################
Depending on your home network you may have more than one coax cable outlet. If so, it is most likely that a 'coax splitter' is used. A coax splitter has one input where the provider signal enters the splitter and at least two outputs where the signal leaves the splitter to go to devices. If multiple devices are using the splitter, the signal for each device will be weaker than if the signal went straight to a single device without running through the splitter. The more times the signal is split the weaker it will become.
[Starhub]
[POE Filter]
[Splitter]
‖ ‖ ‖ +===> [Coax Outlet] Living Room
‖ ‖ +======> [Coax Outlet] Bedroom Master
‖ +=========> [Coax Outlet] Bedroom Large Common
+============> [Coax Outlet] Bedroom Small Common
Most coax splitter have a frequency band filter built in and a label on the splitter indicating the frequency band (for example '5-1000 Mhz'). This means, that the splitter blocks any frequencies outside of this range in any direction. Whilst MoCA operates some frequency bands above this range it should not affect the performance in any meaningful way.
If you happen to encounter issues you can try to replace the coax splitter with another frequency band model such as '5-1500 Mhz' or '5-1750 Mhz'. Another issue might be that the coax splitter in use is extremely old and has ferite cores instead of an integrated circuits. In any case, you can find modern replacement splitters in Sim Lim Square #03-69 at 'UF Technology'.
#### CONNECTIVITY ####################################################
I used RG-6 coax cables and Ethernet CAT6 cables for my home network in order to minimise any potential cabeling issues. Bespoke length RG-6 cables can be ordered in Sim Lim Tower #02-25 at 'LHS Electronics Enterprise' and I found decent quality Ethernet CAT6 cables in Sim Lim Square #04-01 at 'Cybermind'. I also tried to avoid any additional connectors (such as 90° F-type connectors) on my coax cables.
#### MOCA DEVICES ####################################################
According to my research in August 2017, the most recommended and discussed MoCA device on the internet is the 'Actiontec ECB6200 Bonded MoCA 2.0' which promises speeds up to 1Gbps. I ordered directly from Amazon Prime in the first days of the Singapore launch and the package arrived a few hours later. It includes the following:
• 2x Actiontec ECB6200 MoCA devices (120 x 65 x 26 mm)
• 2x AC Adapter (ADP #WA-10P05FU, US Plug Type A 100-240V, 1.3mm connector 5V DC/2A)
• 2x RG6 coax cable (Male F connectors, black, 50cm)
• 2x CAT5E ethernet cable (RJ45 connectors, yellow, 100cm)
• 1x Starburst Technologies 2-way coaxial splitter (5-1675Mhz)
Replacement AC adaptor devices with a UK Plug Type G for Singapore can be bought in Sim Lim Tower #01-05 at 'Ask Electronic' or at #B1-36B at 'IDO Technologies' but the easier solution is just to use a fused adapter.
[Router]---->[MoCA Device]====>[Coax Outlet]====>[Coax Outlet]====>[MoCA Device]---->[PC]
I personally do not recommend any of the advertised DirectTV devices. First, the power adapter is built with an US plug and ONLY operates at 120 Volts. Second, the devices can not co-exist with any video signal as they operate on the same frequency as your TV signal. And in my tests the internet transfer speeds I reached were at maximum ~65Mbps.
#### ECB6200 WEBINTERFACE #############################################
Whilst the Actiontec ECB6200 is a 'plug-and-play' device that doest not require any setup it still can be accessed via a web interface in order to gather more device information. Here are the steps:
• Unplug all cables connected to the Actiontec ECB6200
• Connect the ECB6200 to power and ensure that the 'Power' LED lights up
• Connect your computer via Ethernet cable to the ECB6200
• Set your computers Ethernet IP address to 192.168.144.10
• Set your computers gateway IP address to 192.168.144.1
• Start a browser and open 192.168.144.30
The interface is quite minimalistic with no real configuration options. Here are my default device details for the curious:
Device Info
• Board ID: 6802ECB
• SW Version: 2.11.1.50.6200.7
• RF Channel: 1150
• Band: Band D Extended
Configuration
• MoCA Password: xxxxxx
• MoCA Privacy: Disable
• RF Channel: 1150
• RF Band: Band D Extended
• RF Switch: Hi
#### LINKS ###############################################################################
Before you jump into turning your home network over check out the links below to get a better understand and idea if MoCA works for your home network.
MoCA Technology
http://www.drmoron.org/tv-moca/
http://millennials1st.house/blog/a-sip-of-moca
Coax Splitter
http://cable-connector.sg/page_127.html
ActionTec ECB6200
http://www.youtube.com/watch?v=rhCaZqxVAJE
http://www.phoronix.com/scan.php?page=article&item=actiontec-moca2-network
http://wegotserved.com/2015/12/10/r...ess-network-extender-adapter-bonded-moca-2-0/
http://www.pcper.com/reviews/Networ...work-Extender-and-ECB6200-Network-Adapter-Rev
Other Stuff
http://support.channelmaster.com/hc...ch-Signal-Do-I-Lose-Going-Through-A-Splitter-
http://forums.hardwarezone.com.sg/i...moca-ethernet-over-coax-adapters-3310854.html
http://www.tivocommunity.com/community/index.php?threads/moca-networking-splitter-type.519676/
http://www.tivocommunity.com/commun...tible-splitter-killing-internet-speed.547686/
do i need to change this splitter?? for hitron moca adapter. https://imgshare.io/image/splitter.suoTQ
Borckster
trying to understand the frequencies used. would a higher frequency band splitter work better? ie BAMF 4-Way Coax Cable Splitter Bi-Directional MoCA 5-2300MHz if not , how is that so. thank you for you patience.
Borckster
hello,
anyone to advise .
after disconnecting scv in cable from main splitter.
what if i replace the main splitter ( 5 - 2ghz ) and at the in of the main splitter i connect the coaxial cable which is now connected to moca adapter at the living room connected to router fiber.
the out of the main splitter will go to the other 3 rooms. i am thinking of swapping the 4 way splitter for a 3 way splitter. thanks.
will it work this way. is it any better. thanks.
manyu882
The 1 in 4 our splitter which you have shown is 5-1000mhz pass. Means that it will block MoCA signal (D band ) leaking out to the street.
Change to a 3 way definitely helps signal strength
strigon009
MO closed and not proceeded due to very low interest. :(
I have an alternative offer though... but it's MoCA 2.0 bonded Adapter. If you all interested to know about it, PM me ;). Definitely you all don't want to miss this out.
Hey, I'm interested to get a pair of MOCA 2.0 adapters
