MoCA Network Setup | Ethernet over TV cable
XiaoFu99
How many SCV cable points do you have at home?
I think 5.
3 in bedroom, 1 at living room and 1 at store room.
But my upcoming setup only link 2 points. Router at living room and wireless access point at 1 of the room.
weeza77
With some courage after earlier message, I pryed open the box and finally see the splitter.
I realized that the existing splitter not MoCA friendly. Based on what I read so far, the splitter need to be 5-2300mhz range for MoCA to work properly. Looks like I need to hunt for some MoCA friendly splitter.
I'm referring to your SCV cable point box in your house. Open the box and you will find 2 way splitter. You can disconnect and connect your Moca adapter directly.
manyu882
I think 5.
Since it is just 2 points, then i’d recommend get a female to female f-type adapter to connect 2 cables together. the power loss will be much lesser as compared to splitter.
XiaoFu99
That's only if I know which cable connect to which. A look at the cables doesn't have any labelling. Unless trial and error for various permutation.
My guess the 3 way splitter is for the 3 rooms while the 2 way splitter for living/store room.
weeza77
You need to somehow connect those 2 different circuit together. You probably need 5 way splitter?
weeza77
@manyu882 If XiaoFu99 use his current splitter, his MoCA network will only utilise Band E and F? Correct me if I'm wrong.
manyu882
It's very likely that both MoCA is going to connect to the "Out" of Splitter. Hence, no issue to use Band D ext.
weeza77
@XiaoFu99
This is what I meant by connecting directly.
XiaoFu99
@XiaoFu99
Oh I see.
So basically remove the wall panel and remove the internal splitter to connect directly into the MoCA modem.
Errr. Not sure wifey gonna like that but that's an option. Anyway, already placed short RG6 cable and on the way to SG.
Nevertheless, thanks for sharing.
manyu882
Oh I see.
I think what weeza meant that you can cover the port after that, so it’s quite neat actually. he’s just showing you the inside.
TNG
Need some advice on my next steps.
Do I need to unplug the white incoming cable ?
Incoming from SCV cable point from outside right?
I assume this is safe to be unplugged considering there are no more cable signals from SCV anymore.
But wondering whether that needs to be capped after unplugging ... anyone knows?
weeza77
From what I've read regarding MoCA installation, if you want to disconnect and use the current splitter. You need to install the POE to the splitter.
If like my config, single cable from Starhub to 2 way splitter. I just disconnect the 2 cables from the splitter and joint them using "bullet" F-connector.
TNG
Anyone knows where to get gocoax apart from its website? Its currently out of stock and amazon now doeesn't sell.
thx.
weeza77
thx.
It's been like this since last year. No idea whats happening actually.
manyu882
their stock is unstable. high in demand couple with longer logistic and production lead time.
XiaoFu99
Hi all, just got my goCoax units. Setup was ok and was blazing fast compared with my homeplug.
However, I'm faced with intermittent internet loss. It was ok for few minutes and down for 1-2 minutes and repeat again. Seems like they are catching a breath.
Anybody encounter such issues ? I checked that internet is ok with main router.
XiaoFu99
Another point. My router default gateway is 192.168.50.1
So the MoCA default address when connected directly with a PC via ethernet is 192.168.254.254
I went into the MoCA admin page under static IP, should I change it to be similar to my router subnet (e.g. 192.168.50.88) ?
