MoCA Network Setup | Ethernet over TV cable
goalshot
hi guys, new to MOCA here so appreciate any help you might have. two questions:
1. is it absolutely necessary to install POE filter? Reason being my unit the SCV is locked and it would be a hassle to install it. what's the worst that can happen if I don't install the filter?
2. to prevent data leakage, can I just unplug the cable coming in at the riser?
keenklee
IMHO.
I am not using - so far so good. For security, can consider fixed IP.
goalshot
goalshot
Yup. That's what I did for my SCV cables. Unfortunately, they won't work. Not sure what issue.
However, it work with my TV cables which are also coaxial
I see. Also, I wonder whether it's better to just connect the MOCA adapter to SCV point using a F-type male to male plug rather than a coax cable? This'd minimize any signal loss, right?
Apparatus
Just make sure it works first. Other things can come later
flyingteacup
Hey guys, new to the moca concept. Thinking of trying it out. But I realised my room has the super old radio point and TV point side by side.
I'm assuming none of them are SVC ports. Would I still be able to setup moca?
Apparatus
TV cable is coaxial same as SCV cable
I'm using my old TV points for MoCA
flyingteacup
So just wanna confirm that the conditions are okay for moca before I make a purchase.
The first image are the ports in my room labeled DX.
The other is in the living room lanes scv.
Apparatus
SCV and TV point connector pins are different. The pin for TV point is thicker than SCV which is needle-like. Just don't mix the two
Refer to my past posts.
Apparatus
Ah, saw your previous post showing the difference. In my case it's not possible for moca to work?
SCV point connects to SCV point
TV point connects to TV point
Check your connections again
My 30-yr old HDB house has both SCV and TV points
flyingteacup
Damn. Just checked. Mine doesn't have the old TV point in the living room.
But thanks for everyone's help and clarification!
goalshot
I'm trying to connect using two Frontier FCA252 MoCA 2.5 adapters but it doesn’t seem to work: the power and ethernet LED are on but not the MOCA LED. I suspect it’s the cable in the box (see photos attached). Can anyone tell me if one of these cables should be reconnected or disconnected and how? Thanks!https://photos.app.goo.gl/MZy2SCeTKw4eeYYs9
Apparatus
Disconnect the right side cable and test
Disconnect all the cables from the splitter and connect the 2 cables on the left side with a female-to-female coaxial connector.
If still cannot then likely one or both cables has problem
What are you connecting? TV points or SCV points?
goalshot
thanks. I'm connecting SCV. Will try and see if it solves the prob
goalshot
If SCV points don't work you can try TV points if you have them
Mine have both but only TV points work
Finally fixed it by connecting the MOCA with one of the cables from the cabinet. now getting 500M in the other room for the 1G plan. Thanks for the help!
