Monitor advice required
kingsen
Hi all. Did some research and wish to gather some opinions.
Current:
U2713HM
27" / 1440P / 60hz
Looking at:
BenQ Zowie XL2411
24" / 1080P / 144hz
Any other suggestions?
GPU:
Zotac GTX1070
Purpose:
Mainly gaming (overwatch/pubg etc)
Occasionally movies / dramas
No color editing / rendering / professional usage / work. My pc is purely for casual surfing and gaming.
Anyone switched from 27" 1440p to 24" 1080p? Was it a worthy decision?
Any best value option to purchase monitors (qoo10/lazada/amazon?)
Sent from Samsung Galaxy Note 8 using GAGT
ZrE0_Cha0s
Well best u get it locally. But sadly recent qoo10 code just ended. So u have to wait for next few days for it.
Lazada wise if u have Citi,SC or UOB card can get better codes.
Anyway Benq one is good for gaming. Can go for it.
singupingu
If you need the high hz for more competitive gaming, then switch. If not, just stay with 1440p 60hz.
Or buy the 24" for gaming, running simultaneously with the 27" at the side for media purpose.
Sent from Finally Unbanned using GAGT
kingsen
Thanks for the replies. Qoo10 and lazada comes with local warranty I suppose.
Hmm dual monitors not into consideration yet due to space constraints as my cpu is right beside. If one day I decided to put it on floor.. Beside my subwoofer lol.
singupingu
Not really. Lazada/qoo10 if local seller and stock is local distributors then got warranty. Otherwise don't have or just seller warranty, which you can't expect too much out of it really.
Note the warranty type carefully. Local (manufacturer) warranty is the legit one. Local (seller) warranty is the not so sure one.
Put the cpu on the woofer perhaps? Hehe
superhero41
Current:
U2713HM
27" / 1440P / 60hz
Looking at:
BenQ Zowie XL2411
24" / 1080P / 144hz
GPU:
Zotac GTX1070
Purpose:
ur parts is buy alr or not? cuz now build v ex leh, u wait for 1070 price to drop first. since u using casual gaming n surfing i think any monitor below 300 ok alr.
kingsen
Thanks bro. Noted in the warranty part. Learnt new things today!
Put cpu on woofer makes the screws go loose and my mind also go loose �
kingsen
singupingu
Put cpu on woofer makes the screws go loose and my mind also go loose *********
Am glad to share my findings. Hope you find your buyer soon.
ragnarok95
Senior Moderator
Senior Moderator
Same setup as me. U2713HM with GTX1070.
Only played Overwatch and Starcraft.
Not a pro player, so 60hz good enough for me. Monitor still going strong, i do not see the need to change also.
kingsen
Yea I realise I tend to play all the competitive fps games that's why wanna try out 144hz.
U2713HM is a good monitor for sure. Served me well without any problem at all. Very good for general purpose.
parkson
Why not use both? When surfing net, youtube etc. use your 27" 1440p. When gaming use the new 144hz monitor. Best of both worlds :D
singupingu
Mentioned above table no space lmao
parkson
Time to shift the PC to the floor! Once you go dual monitor it's hard to go back.
kingsen
But u look at different monitor size with different resolution won't feel weird? Sorry never used any dual monitor before so not sure how it feels lol.
parkson
It's totally fine, I've seen people with ultrawide + normal monitor setups.
Or if you want you can get a 27" 1080p 144hz to pair with your current monitor.
kingsen
Hmm OK maybe I go research about how to setup dual monitor with a gpu
singupingu
1x displayport to Dell
1x displayport to BenQ 144hz
Done. Dual monitor.
Then right click empty space at desktop, go to screen resolution. Set which is 1st screen which is 2nd screen and make sure the resolutions and refresh rate tally.
kingsen
Done. Dual monitor.
Thanks! Will gpu be insufficient power as need to support 2 monitor?
singupingu
GTX 1070 leh. It's enough. You don't game on both monitors. One monitor gaming the other idle.
