[Monitor] Crossover IPS LCD 27 inches
Kazzi
I stand corrected. It can indeed scale down, but what I do notice is that even though down-scaling is possible, I cannot activate the monitor using a single-link connection. It will only accept a dual-link DVI signal.
Scaling seems to work well for any 16:9 resolution, which includes 1920 x 1080, 1600 x 900 and 1280 x 720.
That's the graphics card doing the scaling. The monitor itself does not have built-in scaling, hence the need for expensive 'active' adapters for laptop/ps3/xbox users.
There are models with scaling and multi inputs, but the prices are also alot closer to the popular monitor brands.
i1magic
wow. 2560x1440, can game? i run things at full details de..
then again..if i buy this is purely for work and photography..not so much teh game. haha.
If you play the games at say 1920x1080 .... should be ok. But if you want to play at 2560x1440 ... then I suggest you get GTX670.
i1magic
Yah ... even in the website on eBay .... IIRC they specifically indicate that only Dual Link DVI can drive this monitor.
chins
Sorry for noob question. If my laptop only has a HDMI port, am I able to project the graphics over to this monitor at the max resolution of 2560×1440?
eliteFX
Which is recommended? shimian or crossover? gonna order tonight. which website offers warranty? Thanks
keith66
HDMI has a maximum resolution of 1920 x 1080
Swiftbladez
it is general opinion that crossover has better build quality over shimian. Shimian however is the cheaper option.
i1magic
It is up to you. I ordered CrossOver because I want a Pivot version. Gmarket Shimian is cheapest I think about SGD$380 only.
You may refer to the website and ask the seller about the warranty. But whatever warranty, usually buyer have to bear the shipping charges to send the item back.
Also, I would advise that you order on Sunday or Monday. Today is Friday liao, if you order ... you'll waste 2 days. But this is what I suggest lah ... end of the day ... it is up to you.
CrazyBlue
So far so good?
Pivot means can turn here and there right? (w and w/o can use vesa mount? - no need but in the future maybe)
Thought of getting two pivots..cus getting one and using it next to a 25.5" TN panel matte screen..would be weird...right?
newdave
hi, did any one got this 27inch lcd tried to play game at 1080p resolution? is the image quality good at this non-native resolution?
Thanks
boxsurat
Thanks
ya i did try to play skyrim both in 2550x1440 and 1920x1080. both is good although i prefer 2550x1440 cause it shows more.
but I couldn't use highest setting if play with that resolution. that's why i played with 1920x1080.
eliteFX
Thanks for the reply.. I found crossover 27q for 399 over at Gmarket, seems like its cheaper than Ebay. Btw as long as the graphic card have dual link dvi port it will work right.. Might get sapphire hd7850
newdave
thanks. anymore observations are welcomed :)
i1magic
So far so good?
Just get 2 lah ... Pivot means it come with the stand that can slide the monitor up and down, turn left and right, tilt forward and backward. If you get the normal one from CrossOver ... it will be Vesa mount-able also.
Just hoot 2 lah ... I am using 2 now ... very shiok.
CrazyBlue
Ah...poison. u guys (i saw another guy also) got 2 pivot bargained for 320usd each? or something like that?
i1magic
Yes ... you need to have a powerful graphic card to support 2560x1440 resolution with highest settings.
