[Monitor] Crossover IPS LCD 27 inches
zHelix
Interesting 27 inches...I'm interested in getting one for work to make use of the estate space available. Enhance productivity.
I intend to run the monitor via my laptop which is powered by a GEFORCE 9300M GS card and this has a HDMI output port.
I have searched but cannot confirm the maximum resolution this card can support. The spec from NVIDIA appears to suggest it supports displays up to 2560x1600 over Dual-link DVI. However, in my laptop, I only have a HDMI (1.3) output.
Can a HDMI to DVI adapter support operation of these monitors.
omnilancer
Nope. Hdmi max only 1080p
JDee
I bought 2 x 27Q (no pivot), only opened 1 up, so far doesn't look like there's any dead or bright pixels.
Anyway, the other one is up for sale ($420 bought at USD$320) because I realised my desk is too small to accomodate 2 27" monitors. If interested pls SMS @ 94754085.
masotime
technically speaking for all mini-dp ports. But people usually only need such adapters when using their macs because that is their only option of using a secondary display.
It applies to every port that is not Dual-Link DVI. "Dual link" is pretty much a DVI only "feature" that DVI needs to drive displays at such high resolutions.
DisplayPort (mini or otherwise) has no such requirement, but unfortunately since the monitor only has a DVI input, you're pretty much forced to convert every non dual-link signal to a dual-link variety if you want it to work.
I am not sure about HDMI. Technically it is able to support high resolutions, but either way no active adapter to dual-link DVI exists for it so it is pointless to consider.
Even my AMD 6950 only has one Dual-link DVI port... the second one is single-link, and is not able to drive the high resolution supported by the monitor....
i1magic
Would really hope that they could move to Display Port or HDMI or maybe HDMI2 which can support resolution above Full HD.
The DVI / Dual DVI head is very big.
eliteFX
just wanna ask.. for this monitor it needs dual link dvi right? wad does it mean? i have a dvi-d port onboard on my z68 mobo.. or do i need a graphics card?
i1magic
From technical perspective ... it should work.
mofuscherub
When the monitor can't even be turn on despite me trying a few power points.
After further testing and carrying the monitor down to SLT, the fault is with the adapter, have to grab a new adapter. Take note that SLT dont have the adapter with the head for crossover. To buy a new adapter, find one with 24V and 5A then ask the person to solder the head onto the adapter. Screw the QC passed sign on the power brick given.
masotime
Sadly not that simple :(. The single link DVI-D port on my AMD 6950? Looks identical to the dual link port. Just because it has all the pins / holes as a dual link port doesn't automatically make it support dual link. Apparently the graphics card also must be able to drive a dual-link signal out of the port.
windwaver
That's what I suspected (that's why I asked). Good thing you found the problem. How much is the power brick by the way?
i1magic
I can only find this on eBay ... from the picture ... it looks similar to the one that this 27" monitor uses.
About SGD$53
NOTE : This connector to power is "mickey head" type.
Source :
24V 5A AC power adapter for JVC LT-23X576 LCD TV NEW | eBay
i1magic
Har? Your AMD6950 cannot power this monitor? My almost 2yrs old GTX460 is powering 2 x 27" monitor now with no problem. Lucky for me that I don't play game much, if not confirm must upgrade to GTX670 liao.
masotime
