[Monitor] Crossover IPS LCD 27 inches
kaze-no-koe
I would try it out on my shimian when I have the time. I did read people successfully using the ps3/360 with such monitors (non multi input version)
i have read it working only on certain model of catleap which cannot be overclock with a single link-hdmi cable at 720p..but no success to other monitor with single link..nw im only wondering if dual link will work
i1magic
Hi guys,
Just want to confirm before I buy the cross over monitor.
My desktop is using the below card.can support 2560x1440 on cross over. Got dual-link Div,I believe. Can support right.
GeForce GTS 250 | Specifications | GeForce
Can buy thru this link right?
Computer / Laptop -.
This is the model u guys are referring to.
Thanks
Hi,
Based on your gfx card spec .... it shows that it can support.
Yes ... you may purchase from the link above.
Swiftbladez
hmm. then perhaps you can go get a dual link to hdmi cable to see if it works? Anyways I'll try it out on my ShiMian next week once I'm back from camp.
kaze-no-koe
just tried with a dual link to hdmi and it does not work..guess will just have to buy the multi version
masotime
I'm pretty sure that a HDMI to dual-link DVI effectively doesn't exist for the average consumer :s8:. Electrically the standards are not compatible (unless you have the non-existent HDMI type B port), requiring a conversion of the signal i.e. it needs to be an active adapter, and I've yet to see such a one online (a displayport to dual-link DVI is a lot more common).
Reports of it working online are probably because the monitor accepts a single-link DVI signal as well. I know this because I can connect a single-link signal via HDMI to single-link DVI on my old Dell 3007WFP (resolution limited to 1280x800), but it doesn't work on the Korean one that I have.
ilovewhales
Hi guys, 2 questions .
Im using a GTX 670, so can i hook up my gpu to this monitor?
If can, which seller should i look from ? I need it asap. Thanks :)
boxsurat
you can connect GTX 670 to this monitor. i have tried it. but must use correct cable: dual link dvi
i1magic
Sure can work lah .... my GTX460 is powering 2 of this beauty ....
Swiftbladez
if im not wrong the cheapest solution comes from gmarket. all sellers are generally fine.
and no your gtx 670 cannot work, you must exchange yours with my 560ti which i am currently using the power one of these monitors. proven and 100% guarrentee it will work :o
i1magic
My friend is using a Palit GTX670 I think .... and he could run this monitor.
trailblaze
i really tried...but cant find the info on warranty....
hi guys, does the crossover bot from gmarket has any manufacturer warranty?
