[Monitor] Crossover IPS LCD 27 inches
congrade07
I am using a Dual Link DVI on my samsung S27S850 on XFX 7970. No issues le. So I assume the 7970 issues is just limited to few manufacturers?
ralfale
Need some help. Are we able to get seller to test no dead pixel before sending over?
Below seller offers this option but is charging $99 more for this. Crazy!
Computer / Laptop -
Also, is the dvi cable usually included in package?
Edited: found all my answer in above link's user reviews
I ordered on Monday and it arrived on Thursday, it takes about 3 working days for it to arrive at your doorstep by Fedex after ordering. It arrived with bubble wrap as in the picture, the box is not damaged in any way. All the accessories were included, such as adapter, power cable and DVI-D cable. The seller gave some free gifts too, I appreciate that extra effort :D However, it came with 2 dead pixels, which is acceptable under their policy. Before ordering, you should know that these panels are grade A-, it might have pixel defects on it, that's why it is so cheap. Overall, it is still a worthy purchase!
Aegis_2
gratz! welcome to the world of amazing quality for an extremely reasonable price :D
Thanks swiftbladez.
After using for 2 days, just discovered 2 minor issue. 1 is that i got bleeding at the right hand bottom of the screen, but not a big problem to me. The 2nd 1 however is very irritating to me, there is a soft hissing sound after using the monitor for sometime. This sound will not appear in the initial 5 to 10 min. Anyone encounter the hissing sound issue? So far no dead or bright pixel.
noobiee
Wow $325 for a 27" ips with 2560 resolution...
Damn power, dual dvi means need to have 2 dvi cables to work?
i1magic
No lah .... Dual DVI is this ...
ralfale
What is the next best alternative we have for similar screen quality and size locally?
i1magic
i1magic
Did yours get any DP?
I gotten 2 ... 1 no DP ... and the other 1 has a DP that is about 3" from top and 4" from the right. I have a hard time finding it.
Now changing wall paper ... cannot see at all.
