Which model are you referring to?
crossover 27q
2 x Crossover 27Q LED-P27" @ USD$780 (free shipping)
Source :
CROSSOVER 27Q LED-P 27" (2 Set) | eBay
crossover 27q
I just ordered a Catleap 27..
Seriously, why are these monitors so cheap? As compared to Dell which are like 700+?
crossover 27q
Ah i see!thats an extremely good deal!
apparently these panels are A- panels while the dell uses A+ panels. What that implies no one knows exactly except for the fact that the korean monitors do have poorer QC. You also have the lack of support and warranty to start with.
Do note there are other consumer brand variants out there that are "budget" ips monitors as well. The 2 brands known out there are HP and Harzo
just tried offering USD $320.00 to Red-cap as well.. hopefully get it.
You mean that is not a "Buy it now" link and you offered $320?
some users can make it work with their laptops.
what you will need though is an active converter for your macbook to even have a chance for it to work. i think its like from dp to dual-dvi?
Yeah I "Make an offer" .
But 7% gst is only about $35?u have to pay gst as it exceeds $400?
u made offer for achieva shimian?
i got only dp-hdmi.. But got convert hdmi to dvi.. Should work i guesa
unless its the latest version (or the version that supports higher than 1080p) HDMI i doubt it would.
I've also done a brief compilation of the different brands and models:
Budget Korean 27
arh. thanks for the link!
btw u guys got try searching at gmarket singapore? they have but no one buy from them b4. so got no reviews. but it looks cheaper than ebay. i maybe wrong..
ips monitor
