[Monitor] Crossover IPS LCD 27 inches
Teng Zai
I order also the 2735AMG and just got it today. Tested and did not find any dead/bright pixel. Overall quite happy with the panel. Downside is the touch panel does not really work beside the power button and the screen is not as bright as my previous 27 inch display. For the price, cannot really complain liao :D
Huh the OSD controls not working? Quite serious problem ley! Try ctc seller?
Anyway it seems the black tune has quite some issue and don't seem to be super sturdy. Crossover 27Q still seems to have the best built quality due to the full metal built. Cant say for the rest though.
Hoping to see someone in hwz review the QNIX 2710, I'm kinda looking forward to it as my next monitor due to its overclocking capabilities but unsure if the built is good haha.
hm.. i also thought of contacting seller about that problem... but so far the monitor is working without any problem . so i guess i will let it pass with a black tape..
yup, this one is the new blacktune 2735amg ... bought this one coz it look quite nice... build quality wise.. i'd say at MOST 6/10... the white colour bar below is hallow inside... with a bit of force u can push it in.. and the "touch" control panel.... i only finds the power button working(luckily)and it takes abit of getting used to that button... and the stand also , even thou its made of metal... its hallow inside... hopefully it won't give in to monitor's weight after sometime.
Try contact if it's not too troublesome for you haha, AccessoriesWhole is a very reputable seller, he just might do something about it? I've heard of them compensating Dollars-per-dead-pixels for people who got dead pixels on their 'perfect panel' versions, while also offering replacement if they choose so.
I think will hold la haha, even my old samsung like going to break like that, plastic hollow stand but still last so long and when I move it i accidentally knock so hard it bend abit but still there and standing strong :p
Xreedom
Bro, its not OSD, it just manual button to adjust backlight and volume.. so no OSD will show up, also take abit of getting used to learn to press it. its working ,
i didn't buy from assessorieswhole, i bought from Buy2Korea. i wasn't planning to contact the seller about this, but since u guys wanna know i am contacting him and update u guys with the response later.
Teng Zai
Ahh i thought that one got OSD. But isn't it already a big problem if you cant adjust volume and backlight?? Haha. Hope you enjoy yr 1440p anyway, besides that little eyesore crack ;P
Teng Zai
I think there's a thread for it somewhere.
http://forums.hardwarezone.com.sg/m...volution-ii-27-matte-pls-monitor-4200102.html
Haha, at $339, I'm really tempted.
Wah I don't even remember, I even post in it before.
But lots of people saying it's wobbly and fragile stand leh, but cant blame for the price we're paying.
$339 still can stack some coupons, easily bring down another $10+ hahaha.
Price and the overclocking capabilities most tempting to me, might hoot one on christmas.
cloud77
thanks for sharing. Did not use the speaker cable thus did not try the volume. I like to think BL stands for back light ? you just keep pressing is that correct ?
aptget
No you didn't but you did recommend X-star and Qnix. I looked at both and chose Qnix instead.
Stand is wobbly, i just shook it. But who shakes a monitor ? :s13::s13:
Teng Zai
qoo10 is havibg an offer now. 30 cheaper than usual for all models.
I don't think so leh. If you select Crossover 27Q Black standard, it now shows +$30, which then returns it to the same old price of $380, If I'm not wrong?? :s22:
yukita
so, if i were to buy one using on my pc, maybe use DVI connection, which model is actually the best buy ... i read and read become confuse ...
thanks in advance.
Teng Zai
thanks in advance.
I think most require Dual-Link DVI. Check your GPU if support DL-DVI, monitor such as the Crossover 27Q only support DL-DVI. SL-DVI I don't think can support that ress.
Anyway I'm pretty sure got some models support Display Port & HDMI.
Best buys IMO would be the Crossover 27Q(Price and built quality) and the QNIX2710(Even cheaper, and can overclock up to 120hz+, but some state the stand quite wobbly). Your best bet would be to get from AccessoriesWhole on Qoo10/Ebay. Pretty sure its cheaper on Qoo10.
Swiftbladez
There are models that support hdmi as well.
I would recommend people considering to buy any model to search up on Qoo10 first rather than eBay. The price is definitely much better on Qoo10.
yukita
thanks for the suggestion... i checked the price for the crossfire 27q... its around 390 .... is the price alright?
Swiftbladez
yeah thats about right.
if you don't mind the design of 27qw, you can pick that one up. qoo10 having time sale for it now. only $350.
Teng Zai
27Q is the metal built without speaker.
27QW should be the one with speaker but built not as good.
I personally recommend the 27Q over the one with in built speakers.
IndoASK
Hi Guys,
I'm torn between the 2 models: qnix qx2710 vs crossover 27q. Which one is the better choice?
Edit: I've decided on qnix qx2710, now the question is should I get matte or glossy :D
solofire
sorry just asking if Crossover BLACK TUNE 2735AMG and crossover 27q is using the same panel.
read up about it other panel dun have the same model number?
they said Crossover BLACK TUNE 2735AMG is same as mac 2012 panel
so us 27q same as mac 2013 panel or still 2012
