[Monitor] Crossover IPS LCD 27 inches
shadow84
Would the QX2710 LED Evolution ll DPort be a good choice? I want the DP and hdmi, and would be wall mounting it...
IndoASK
jhlee83
Hi all,
I would like to get advise on crossover 27QW IPS LED which I saw on Accessorieswhole on qoo10.
thanks.
lh_nerd
The metal strip at the bottom is not properly aligned confirmed. Anyone having buzzing noise issues? My monitor buzzing noise very minimal. But my friend 2735amg buzzing noise is quite loud
Teng Zai
Quite a common problem. My 27Q buzz when PC is off. When my PC turned on, buzzing gone. So when I turn off my PC, I switch off the power to the monitor so no buzzing.
cloud77
cannot really tell whether got buzzing as my desktop PC fan is quite loud. If should, should be tolerable
jhlee83
Yes mine have the high frequency noise/buzzing as well. Even the power block also have it.
But I think it's bearable, and most of the time I'm on my headset.
I've contacted AW wrg to this, waiting for their reply.
ultimate700
What do I have to check for?
if i buy over $400 will i have to pay extra for tax?
