[Monitor] Crossover IPS LCD 27 inches
i1magic
Time to upgrade your monitors too :) Get those Korean monitors with HDMI (the cheapest variant all has HDMI now AFAIK).
Got link to those? I can't seems to find.
Upgrade? Then this 2 CrossOver how?
I found this, got DP input.
Price : About SGD$232
https://www.ebay.com.sg/itm/Off-Gra...149393?hash=item36028ed651:g:k6cAAOxyUrZS5gm3
i1magic
Hi,
I ordered 2 set on 17 May 2012 (Thursday) also.
Received 1st set on 21 May 2012 (Monday).
Received 2nd set on 22 May 2012 (Tuesday).
Which seller did you order from? Actually, for those who wanna order this monitor, the best is to order on Monday or Tuesday and chances is that you will get it on Friday if you are lucky.
Reporting in to update. Still using this 2 monitor that I bought in May 2012.
One of them has a burnt LED driver board, which I got a replacement from the seller around 2015. Both the power adapter were spoilt from 2016 to 2018 and I bought power adapter with output 24V 5A, then use the following method :
To switch the connector head over and continue using the monitor.
After more than 6yrs, both monitor are still going strong. Only problem now is that, newer graphic card only supports 1 Dual DVI port. To upgrade graphic card means have to change monitor also liao.
birdiehuat95
Troubleshoot
Hi,
Mine's a FAST144 from Crossover. Only used it for 8months when this happened. Basically, the screen starts showing these when powered on one day. It has been good with no problems for the past 8 months so wondering if anyone can help with it.
https://imgur.com/nuNs5do
i1magic
Hi,
Seems like panel fault. When you switched to different input, is it still the same?
Swiftbladez
I remember got ppl say before that it cost almost the same cost of the monitor alone LOL. Some sellers might pay for the shipping though, not sure.
turboo
Hi guys,
I know the seller mentioned onboard gfx doesn't work with 27Q, but that was a few years back.
Will it work if I have a Ryzen 2200G (vega onboard) or the UHD620 instead?
turboo
Hi guys, I just shifted house and my 27Q was working perfectly all along. When I tried to plug it back in today, there was a green blinking light on the Welltronic power adapter, and no led light at all on the monitor itself. If I unplug the power to the monitor, the green light on adapter is always on and stable.
What is the issue then? :(
i1magic
Retired my Crossover 27Q LED on 29 Sep 2022. 10 years, much worth and value.
What happened to it?
I got 2 around May 2012. Along the way, one of them change one PCB and continued on. After that, the power adapter died, change and continue using. Until recently, one of them, sometimes can turn on, sometimes it doesn't. It is a "hit or miss". While the other one, still going strong.
