MyRepublic fibre - Part 4
leaving_footsteps
Could something be done with the extremely low speed with 天籁K歌?
It took me over 10 minutes to download a 20MB song.
The same song took me 20 seconds on M1 4G.
creator88
Best way to transfer files between MR users
Hi guys,
What is the easiest and most efficient way to transfer large files (>1gb size) between MR users? Assuming both are on the Pure Plan (no static IP).
Is FTP possible between two different MR users?
Would appreciate any advice on the above.
lukestar
Hi guys,
In theory FTP possible if both are static IP. Dynamic I not sure. But then I also duno MR got block FTP ports...
leaving_footsteps
Hi guys,
Create a torrent?
misato
If both are dynamic IP, I don't think there will be an issue communicating to each other (I have tried it before with my friend). If either one is not on the dynamic IP, then communication to the port hosted on the end with Dynamic IP will fail. The end that is on dynamic IP will have no issue accessing any destination thou.
imacbie
DDNS services will do the trick
noip.com has a free service and even tutorial to help u set it up
they block no ports :)
i using some of this programs, 千寻影视HD, Cloud vod, 乐视视频, Cloud tv, TV entertainment, TV episodes,风行影视 etc, on my android devices. running on MR network. it is very slow and buffering like no one business.... try on other ISPs... i considered them as great and not much of a issue. how about the bros here...
cyberet
my cloud vod is working fine, with min buffering at the start.
cloud tv i believe is the server side if you are viewing the free channels.
ckyeungken
Dear All,
Just a quick question.
I am getting MR Fiber broadband with Homevoice. For the new ONT installation, does RJ11 connect directly to ONT or RJ11 to connect to a Analog Telephone Adaptor, and ATA to router?
Thank you
lukestar
Dear All,
Thank you
If you are getting the new 1gbps or 300mbps, RJ11 goes direct to the device. There will not be any ATA from what I heard.
creator88
So even if both MR users are on Dynamic IP, FTP is possible?
Key steps I assume are:
- both MR users do not reset their routers (so as to retain current dynamic IP allocation)
- one party sets up a FTP server
- other party accesses the FTP servers and transfers the file via FTP
Workable?
imacbie
Workable?
hmm. i dun see why it won't work.
misato
Workable?
Port forwarding needs to be configured properly for the side thats hosting the FTP else it wouldn't work as well.
xRenol
If port forwarding is required, then by default MR dynamic private IP would not work.
