MyRepublic fibre - Part 4
newbish
Clarify - I can access using static ip but can only vote for a single celebrity 1 time.
With dynamic ip, i can use firefox stealthy extension to do multiple voting for the same celebrity.
For static ip i could not get firefox stealthy extension to work
So i need to access that website using dynamic ip.
uh... so earlier you claimed that you cannot access the page...?? Now you say can access but only vote 1 time? Is this even related to MR :s11:
danxiaogui86
Is the page to only let 1 ip 1 vote? or 1 ip can do many vote?
what is the clause for the website that one person only one vote? or one person can vote unlimited time?
xRenol
According to the webpage, it stated that only 1 vote per day. So I assumed that 1 IP is only allowed to vote once per day.
The firefox stealthy is to hide the IP address for privacy online and access all content privately without censorship; bypass firewalls.
xRenol
Am I right to say that you can access the webpage on BOTH Static and Dynamic IP?
If yes to the above question, then to be fair to MR this should not fall under MR control.
Static IP will be forever the same IP that is accessing the webpage but the Dynamic IP can be a different public IP due to the converting of private IP to public IP to access the webpage.
I believe the behaviour is normal under network context.
frizee
Hello MR,
My contract ended last week, and prior to that, i have already signed up during the very initial announcement of 1gbps plan.
Until now there's no calls from MR on installation date? May I know what is going on? :s11:
nez
To clarify, i cannot access the page through dynamic ip :o
nez
I believe that is correct.
Yeap. Using this to do multiple voting. which static ip cannot work
nez
With Dynamic IP not all the time can access.
You are right. I was so focus on the dynamic ip i forgot about where the issue is. But family wouldn't be able to understand this
hangyong
Thanks. The issue is on static ip, firefox stealthy does not work. Any work around?
I think you better write out your whole problem here again and give exact problem description for people to help.
one moment canon t access through dynamic IP, then say static can only vote once while dynamic with stealthy can vote multiple times, then say issue is on static.
This kind of problem description is not going to help in anyway to getting your problem solved.
Warlock86
My engenius router can't seems to transit any wifi signal. At the same time, it does not permit me to access the router via router ip address. Will MR replace a new router for me?
nivleK1985
Do a reset followed by a direct connection. And see if it's connected. Not able to access router ip is werid. What are the light status. And send me your customer id.
LooseCannon
Regarding this and other related china-website access problems, anyone still facing issues?
Of cos there are still issues. The China access issues have not been resolved ever since reported last year, and there was no communication to users that you have, either through this platform or via the support tickets that have been logged. You even asked me to send you PM last year, which I did, but you ignored completely.
Have stopped asking only because it seems to have gotten nowhere and it's a pure waste of my time.
Why don't you share with everyone OPENLY here what has been done so far to resolve the issues then?
nez
To summarize, are you able to ACCESS the webpage on Static IP and Dynamic IP WITHOUT firefox stealthy?
Dynamic IP - Sometime can access that china website, some times cannot.
(using firefox stealthy is only to enable me to do multiply voting that all)
Static IP - I can't be 100% sure if all the time can access that china website as i usually use Dynamic IP)
(However, even if can access, i can only do a single vote, as firefox stealthy cannot seem to work in static IP)
firefox stealthy acts like a proxy for me to allow me to do multiple voting. Hence it has nothing to do with whether able to access that china website.
Hope that clears my earlier query :o
UltraSonicEX
Why will you all need to access China Website? What is so Important of whether your Ip being Dynamic or static?
You just can get a VPN and every works in wonders.. Don't tell me you guy do not know?
Some website like in the Singapore is disable such as Youtube (Certain Videos)
so just use VPN which is a USA IP- POOF. Done. and you are in.
nez
Family need to do voting, every single day. Apart from that, got access to weibo, etc...
I can't do multiple voting with static ip. Hence i need to access that website through dynamic ip.
Not familiar with VPN but do you mean i can change VPN's proxy many times?
Cause this is how i do multiple voting:
1) Activate firefox stealthy
2) Vote & answer question
3) If answer is correct & vote goes through;
4) I need to clear the cache;
5) Then I 1st need to deactivate then reactivate firefox stealthy again
6) **Repeat step 2 & continue*** hundreds of times
We use to average about 100 votes per day last year but lesser now as access through dynamic ip is well ...........i guess i no need to say.
So if VPN able to fit my requirements, & few dollars i don't mind.
frizee
Hello MR,
Anyone from MR can assist?
