MyRepublic fibre - Part 4
nestorvie
Hm.. Finally it's my turn for the installation (1Gbps plan)..
But the download cannot hit higher than 610mb/s :(
did you test on speedtest.myrepublic.com.sg?
If that site won't give close to 1Gbps you can refuse to sign the hand over form.
wizardundo
It is thru router (Model: ASUS RT-N15U)
I got the same result using the "http://speedtest.myrepublic.com.sg/"
Did they accidently gave me the 600 mpbs plan instead?
The installer already left.. :(
ArleFK
No such thing as 600Mbps plan la:s13:
Connected directly to the ONT with Cat5e/6 cable?
nestorvie
It may be the router... try direct to ONT first.
mister38
installer come n gone but fiber still red led !!!! tonight got wc .......sian
Lehnsherr
The N15U max u get 600Mbps its normal. You need to change router. That is why they recommend to upgrade if going for 1Gbps.
wizardundo
is it? I see, but they never told me that. Alright, I will try to give them a call soon. Thanks for telling :s12:
alamakazim
Sian.... Wait whole day.... Still no see installation guy....
Call 15min ago, still no reply
keanteac
MyRepublic Brother, when is my turn for the upgrading ?
Can check for me ? Thanks.
Your Account No: C1008412
alamakazim
1gb faster
but response slower....
can download more and faster
but it cripple the whole surfing experience
wweixian
hey guys,
finally got my 2nd date for installation today.
came home and shock to see the wireless from M1 100mbps is so much better at avg. 40mbps DL, 30mbps UL....
to MR 1GBPS plan, giving me wireless 20mbps DL, 2 mbps UL.
Yes, I know wireless is depends on *blah blah we know the drill*, but hardware and such are all better quality than M1! same, distance, same computer. way lousier results. Do i need to configure some stuff??
ArleFK
hey guys,
Which router you using?
