MyRepublic fibre - Part 4
misato
Are you MR staff? :s8: or some service line people that keep getting hammer by your poor service?
Just another MR user. You can consider me as working in the service line.. except the difference here is people pay to get f**k by me in a nice way. Usually smart aleck get the worst treatment from me as it always means I have to undo his mess first before I can get them on the right track resulting in more unproductive work done.
UchihaSasuke
Just another MR user. You can consider me as working in the service line.. except the difference here is people pay to get f**k by me in a nice way. Usually smart aleck get the worst treatment from me as it always means I have to undo his messy first before I can get them on the right track resulting in more unproductive work done.
Haha! Funny, sound like we got similar work :s13:
Anyway, MR really need to look into these ongoing issue, whenever MR have problems, i will need to switch the network to starhub -_-
Demikidisme
1gpbs plan
why am i getting such low speeds with wired connection?
switched to wireless and it gives me around the same speed as wired?
what is going on? i was getting steady 850-950mbps during the first 1-2months since activation in april.
cust id: C1018690
tuckloong
1gpbs plan
cust id: C1018690
ya got ups and downs de..recently...try test again a few hours later
xRenol
1gpbs plan
cust id: C1018690
Did you test with direct connection from ONT to rule out any possibility with the router?
lOi
Anyone getting problems streaming from netflix?
Teleport seems broke for me, i've tried resetting the ONT and rebooted the router, still the same problem.
I'm having to resort to using hola to stream now. :(
Groudon
1gpbs plan
cust id: C1018690
That limit looks like FE speeds... Can check if your NIC negotiate with router to 1Gbps or 100M? Else, try a different cable?
Groudon
Yeap, Teleport (Netflix at least) is showing a region error.
LoneTraveller
I'm having problem too... In CCk... :(
well, how about trying my fix below?
MyRepublic fibre - Part 4 - Page 488 - www.hardwarezone.com.sg
i'm currently watching HD stream right now at Netflix:D
The key is to switch the primary and secondary MR DNS address and then switch back again when necessary. Rebooting of router won't help, at least in my experience in Teleport.
cheers :)
Darknights
i'm having problem with netflix as well. it seems like they have a limited connections for teleport to work.. and it's currently over subscribed. so during peak period, it'll depends on luck whether it works. this itself is disappointing. it's like they are not even able to sustain the number of connections.
i'd tried switching the pri and sec dns around and did a flushdns, it didn't help.
arch angelz
LoneTraveller
cheers :)
guess i spoke too soon. best case i got now is
https://www.dropbox.com/s/5dij3lld5hqlguy/Screen Shot 2014-08-06 at 11.07.32 pm.png
a case of "go up the mountain too many times and meet the tiger"? :s13:
Sensational
wah what game u playing sia...
just playing cs:go only leh. i got so frustrated that I called the hotline and she said she is gonna reset the connection for me. see how it goes now.
EDIT: same thing. restart already also no use. keep experiencing the spiking issue. come on myrepublic what is wrong with you all? email don't reply, call also don't answer.
Lehnsherr
got try direct to ONT or not
Sensational
yea tried alr still the same man. their customer service really cmi. call them they put me on hold for so long. use live chat they said i was the next customer and then the next thing they go offline?
Lehnsherr
what are the circumstances in which the lag will incur? just camp one corner will lag or if you do something like shooting etc etc then will lag.
Sensational
everything man. like i am just playing right the ping will suddenly go to the 1000 plus range then drop back all the way to normal. this occurs very frequently. it makes it totally impossible to play fps like that man. one moment I aim my scope next moment i died cause of the spike and lag.
whoooo
U dint play battlefield4, fuxking enemy just float across me, ****i empty whole 200rds into a camper and dint get 1 hit marker, he got up and even manage to shot me...ccb
