MyRepublic fibre - Part 4
nez
Any termination fee for MR? Planning to sign up with Singtel 1Gbps Unlimited Fiber for $50 instead.
DXMachina
Ok guys, am going a little crazy over this problem I'm having. Hope perhaps some gurus here/the MR reps may be so kind as to shed some light on my issues. :)
I'm on MR 1Gbps and the ASUS N66U router. Everything works fine until I start torrenting, then somehow my connection starts to get wonky and very spotty (webpages display "This webpage is not available" for a second before refreshing, albeit slowly). Even when I stop torrenting, this persists for quite a while before everything is back to normal.
Now, here you may think torrenting is the issue, but my connection absolutely flies when I connect my PC straight to the ONT, bypassing the router. Torrent speed is high and webpages load absolutely fast and fine.
At first I thought my router was faulty, but I just went down to Avertek last week to get it changed to a brand new unit, but I still experience the same problems. This has been bugging me for quite a while now that I'm even willing to pay some experts to come over to my place to have a look :(
Anyone would be kind enough to offer some help? Would be greatly appreciated!
xRenol
I assume your contract has completed.
There is a termination fee of $48.15 for ONT collection unless customers choose to return the ONT to MR.
A Clear & Complete List of MyRepublic Service One-Time Charges
I'm on MR 1Gbps and the ASUS N66U router. Everything works fine until I start torrenting, then somehow my connection starts to get wonky and very spotty (webpages display "This webpage cannot be loaded" for a second before refreshing, albeit slowly). Even when I stop torrenting, this persists for quite a while before everything is back to normal.
Do you only encounter the issue during torrent or randomly?
DXMachina
Actually I did encounter the issue sometimes even when I'm not torrenting, but I notice that whenever I torrent, it's when this issue is at its most aggravated. Not sure if this helps the troubleshooting, but I also notice that my torrents sometimes resets back to 0.1kb/s and sometimes they are back to 1mb/sec etc.
xRenol
I not sure if the torrents that went down to 0.1kB/s are due to the seeding.
necxross
Try disabling router firewall, update N66 firmware and limit bittorrent connections to under 200. Tips from my company engineer. He experienced the same thing. It's a router NAT issue.
Solkarnar
And my ASUS N66U has no such issues. Try using merlin firmware to see if it fixes the problem. Also try to disable QoS on the router.
aptget
what happened to the promised speed ?
Last Result:
Download Speed: 329505 kbps (41188.1 KB/sec transfer rate)
Upload Speed: 472044 kbps (59005.5 KB/sec transfer rate)
Latency: 10 ms
Jitter: 1 ms
18/02/2015 1:47:55 amp
nez
Thanks
Also realized contract is up to May. So 3 mths more. Looks like gonna miss out on Singtel offer
xRenol
No issue for me.
Last Result:
Download Speed: 940156 kbps (117519.5 KB/sec transfer rate)
Upload Speed: 476055 kbps (59506.9 KB/sec transfer rate)
Latency: 2 ms
Jitter: 0 ms
2/18/2015, 11:12:11 AM
aptget
No issue for me.
Last Result:
Latency: 2 ms
Jitter: 0 ms
my issue resolved, reset the router and everything's back to normal
ry0suk1
anyone know how come my 1gbps become 100mbps only?
QOS Disable on direct connection.
Last Result:
Download Speed: 94774 kbps (11846.8 KB/sec transfer rate)
Upload Speed: 92077 kbps (11509.6 KB/sec transfer rate)
Latency: 3 ms
Jitter: 1 ms
2/19/2015, 1:44:10 AM
CoolRock
Last Result:
Latency: 3 ms
Jitter: 1 ms
Your ethernet adapter is megabit or gigabit one?
tuckloong
Last Result:
Latency: 3 ms
Jitter: 1 ms
hehe speed returned to normal around 4 this morning :D just nice for champions league
mach0men
I cant seem to hit more than 500mbps no matter what i did. I am connecting via ASUS N56. Am on the 1GB plan.
SZQddy
Hi,
I am on Pure 100Mbs plan (due to expire soon).
Trying to connect to work with VPN (ShrewSoft VPN) but am getting negotiation timeout error. However, it seems to work if I use my phone as a Wifi hotspot (singtel).
I have a Belkin Wireless Surf router. There are no VPN options in the settings but I think it does support VPN passthrough.
I don't have static ip add-on, is this the issue?
Any help would be appreciated. Thanks
danxiaogui86
Hi,
Yup, U need static ip if u need to connect vpn
