Need Help on my new pc
bloodlovers
To be honest with you, a core i5 6500/6600 is more than enough for your autocad usage. I really do not see a need of 6700 or a 6700K. Why? The reason why you need so many threads is because beside running autocad, you will be assume of running other software side by side. But still, for your usage, i will just go for a 6600 setup with a 1070 and 16GB memory.
Given a choice, defnitely a 6600 over a 6700
Sent from Samsung SM-N920I using GAGT
ragnarok95
Senior Moderator
Senior Moderator
Just get a 6600 with a B150 motherboard. Get a GTX1060 to save more money.
MianBaoFren
Iron_Maiden
i have seen some pc shop like pc themes, videopro, fuwell, tradepac, bizgram, best price.
Which reliable shop should i buy from?
MianBaoFren
we generally recommend pcthemes. the bulk of cost savings actually come from online deals. and one last thing. are u planning to fix it yourself or get the shop to do it for u?
Iron_Maiden
change the ram to 2133mhz. slightly more savings but u dun need that extra speed.
oh and here is a good deal for u.
http://list.qoo10.sg/item/SEAGATE-SEAGATE-3TB-HDD-SV35-ST3000VX000-7200RPM-64MB-3TB-3-5-SATA3-STORAGE/479304720
3TB hdd cheap. get the cart coupon for $10 off and buy a $100 gift card for another $3 off. too bad u missed the wednesday mastercard coupon otherwise u could have gotten it for another $10 off.
is seagate good hdd?? i heard seagate spoilt easily. Is that true?
MianBaoFren
very good question. this one is actually debatable. some pple use no problem, others got daiji. it's all luck. but @ that price it's hard to resist.
get the shop to do it for me.
then u best go to pcthemes. i am not clear on this but i think they do help u assemble if u bring your online purchases with u too. also, do not buy the retail OS from there. get it from reddit @ windows software swap. it's way cheaper.
https://www.reddit.com/r/microsoftsoftwareswap/
Iron_Maiden
the windows 10 pro license i buy online. the software i download free.
ZrE0_Cha0s
Seeing this threads makes me lol. So many ppl giving advice like shooting each others. XD.
