Need Help on my new pc
bloodlovers
ragnarok95
Senior Moderator
Senior Moderator
bloodlovers
Puget system.
I would have prefer to read real life experience from users.
You cant deny that their explanation of each part is concise and easy to understand . Which is the whole point.
Its not easy to satisfy the argument on what is better because humans always have their own bias. I feel the 4790k much faster than 6700 in autocad but how much of that is my bias?
Sent from Samsung SM-N920I using GAGT
Iron_Maiden
Thanks bro for ur recommend. I dont do high end autocad. I dont do 3d autocad. just a 2d autocad. I am more on downloading, movie, gaming and music.
Another question, what ssd and casing do u all introduce?
thanks
ragnarok95
Senior Moderator
Senior Moderator
thanks
You can consider casing from Fractal Design or Nzxt.
SSD wise, if you intend to run everything off the SSD, i would recommend crucial MX300 525GB ssd.
Iron_Maiden
how abt samsung 850 evo 500gb ssd?? is it good?
how abt corsair 400c casing??
ragnarok95
Senior Moderator
Senior Moderator
Evo is good but i will save more for that little increase in storage space.
ZrE0_Cha0s
anyway TS can u list your requirements and budget as well? i re-read again from 1st post to dunno like 10 and i give up :s13:
+usage for the pc.
onenineeight0
Sorry to hijack your thread iron maiden, may i ask
1) Is iron maiden's setup good for playing mmo like blade and soul?
2) Based on the setup, what monitor is recommended(my budget is about $700 for monitor)?
Thanks
undead102
Thanks
Based on his/her first post rig listing. Gtx 1060 is good enough for 1080p Blade and soul. Can max out on the graphics detail setttings for blade and soul 1080p.
Get a 23/24inch 1080p dell monitor good enough.
MianBaoFren
Thanks
his set up is si beh messy lol. $700 for monitor is about halfway for a 1080p 144hz monitor to a 1440p 144hz monitor. the former costs about 300 if u got get it @ a good timing; the latter is around 900s.
u could get a 1440p 60hz monitor though. sharper graphics but fps capped at 60. i think blade and soul does not require fast fps?
