Note 2 battery life
carey
Wah ... your battery life seems very good leh.
What launcher are you using?
Thanks - when I first started with S3, my battery life was horrendous...hahah
Then I found a very good guide which I posted on this thread a while back :D
I am using Apex Launcher
carey
Yes ... don't know why also. Anyway to find out?
My "Android OS" and "Android System" tends to be draining.
If that is the case, then you have a lot of apps running in the background or rather staying awake instead of sleeping...hahah
I use System Panel and CPU Spy to help me...
System Panel shows which apps and processes are running and how much CPU time they used etc
CPU Spy shows the amount of time your CPU spent at each clock speed - ideally it should be in deep sleep most of the time
Let me post a picture of my CPU Spy later :s13:
i1magic
Could you repost your guide?
V
victorlht88
Guest
My battery life on lj5 is good too, hitting 5hrs plus screen time on wifi though.
I use setcpu and downclock to maximum 1ghz.
ChaoAhGua
Cyanogenmod Epic 4G: Battery Optimization Guide (Cyanogenmod Epic 4G: Battery Optimization Guide)
Here you go :s13:
Done the following guide, hopefully will improve :D
Turn off haptic feedback and touch sounds
By default the phone vibrates when you touch menu options or type on the onscreen keyboard. Vibration uses a lot of power. Sounds when you touch the screen also use a little power.
Settings > Sound > scroll down to System
Dial pad touch tones - many users like it, others turn it off so it is silent when dialing the phone to avoid bothering other people.
Touch sounds - default touch sound is very subtle so many choose to keep it. You can save a little power if you turn it off.
Screen lock sound - also subtle, I personally keep it.
Vibrate on touch - strongly recommend to turn this off if you want to maximize battery life.
carey
Hi,
Gam xia very much. Will try. Just curious ... did you enable "Power Saving" on the phone?
For me, I found that there's no difference
So being the rebel that I am, I turned it off :s13:
carey
Yup, let us know if it works...hahah
Personally, it did wonders for me...
When I was using the S3, I would run out of battery by 2pm
After the guide, the phone could last until 10pm based on the same usual pattern :s13:
Ruriel
I tried on my Note 2... not much diff leh. But I kept the haptic feedback off liao, coz I'm starting to get used to it already. :s13:
carey
To be fair, it takes a while
More importantly, after the tweaks your phone should be in deep sleep most of the time when you are not using it...
Otherwise, you may still have apps or processes keeping your phone awake - just look at the awake versus screen in the battery chart for clues - especially if you see large chunks of awake when the screen is off...hahah
albertchng
ya, deep sleep like this...
i1magic
I checked the list already. I have done most of them already except "Keep Wi-Fi on during sleep" ... and set to "Only when plugged in".
Seems to be better .. but will monitor somemore.
pixxie
not sure if this is the right thread to post, but is it possible to use S3's usb cable(bought from gmarket) to charge note2? because i've used my friend's cable & suddenly it stopped working after that. went to borrow another cable, but charging takes forever.
ChaoAhGua
Not bad.. used internet facebook and play games all the way for 2hrs. Drop about 20%
