EveMuffins
- Mar 16, 2005
Bros, can teach me step by step how to go to this page?
Hi guys, can you take a look at my battery stats for me?
I can only get around 4 hour of screen time from 100% to around 15%, which is kinda fast I feel. I only use it for whatsapp/msging most of the time, can you guys take a look for me? Is it a problem with GoSMS?
For today, my battery drained exceptionally fast. I wanted to post at XDA but I do not have 10 post. Here is the pictures.
Try,
Disable your Google Account Sync.
Find a place with data signal or wifi signal connectable to INternet.
Enable your google account sync.
Disable any sync not required like picasa.
Check that All sync completes.
Test again.
Install betterbatterystats to find the culprits causing battery drain.. Mentioned lots of time within this thread already..
Im using stock email app. Sometimes loading n downloading of stuffs are slow n sometimes incoming email is a little retarded to come in. But i prefer this over the yahoo mail app which drained battery severely.
There are many other mail app like droidmail or something like that but have to go through many greek setting uncle like me catch no ball.![]()
How about free ones?![]()
I can't seem to sign my yahoo email in with the stock email app, any help?
Yeah I managed to connect with just .Com
Just to check, my battery life is Screen 42%, Android system 14% and android os 9% that's normal?
yes, your screen will be the single thing that sucks the most battery life out of your single charge. very normal
Use the app DeepSleep to prevent apps or data from sapping your battery while your phone is on standby. said to save battery efficiently and well reviewed.
haven't sufficiently tried it myself, just installed it a few hours ago but 5 hours have passed and only dropped 4%. about a quarter of the time i use to whatsapp and phone call. will monitor a few more days
hi guys, is there any way to make ur note 2 not drain up so much battery when it's asleep? mine drains about 20-30% at night when im slping, it doesn't goes into deep sleep. And if i need to download any apps to assist the phone to go into deep sleep, will it affect things like i wont receive whatsapp msg when the phone is standby?
And is it normal that my android OS is draining the most battery most of the time? most of the time it drains more battery than the screen. Thanks in advanced for any help.
Do u have yahoo mail app?
Did u set weather widget at home screen?
Did u off wireless network at locations setting?
Deep sleep battery saver, it forces your device to go into deep sleep and disables your 4g/WIFI.
The app only wakes up after a certain period for some time to sync data.
yeah saw someone recommend it and went to see the reviews but saw some bad reviews about it. are u using it? so does it means when my phone is on standby mode i will only receive my whatsapp msg after quite some time?
