Note 3 Battery Drain. HELP.
mr_voodoo
had similar issues
switched of Volte and battery levels are back to previous levels
not worth it imo, will probably let you guys to test it out and make it slightly more stable and release power efficient upgrades before I switch it back on again.
DSSS11
I experience the battery drain only when I roam overseas(2hrs drop 50%). When back in Singapore the battery life is very good (78% from morning to late night).Have anyone of you experience this????
ahber79
Read the posts above. All of us experienced this while roaming. No idea what is causing this.
bulldozer88
I have exactly the same problem. Drain overseas and perfectly alright in Singapore. Only happened in July onwards
Before july, all travels were ok.
fatangel
actually many other countries already in progress of introducing volte like what singapore is doing.
the batt drain is indeed probably due to the software, which i think there is one coming along based on the trend on sammobile... Just gonna wait and see how it goes..
in progress of introducing VoLTE?
Means have not launch VoLTE right?
So cannot say like Singapore is doing as Singapore have launched already.
Have you tested overseas?
I kind of believe the overseas travellers.
If some one share something it could be possible that it happened.
Rayall
had similar issues
do you still have the green/red arrows after switching off VOLTE? My stays on.. even when i have disabled 4G!
FreshMaker
it's back to normal now that I'm back in Singapore. It was happening during a business trip to china. turned wifi on only (airplane mode + wifi).. I wonder what in china caused it to have 5-6 hrs per battery and wakelock disabled. battery life is now back to 40 hours per battery back in sg. :s13:
my one same... and it happened only recently like for the last 2 months..
everytime i travelled to thailand or chinese, the phone from 100% every few minutes drop 1 percent... usually in 6-7 hours my phone is flat.. but in singapore it is back to normal.
anybody any idea why...???
mr_voodoo
Nope gone. I downgraded my Os as well to be safe, so might have reset it fully
FreshMaker
Go to Settings -> Device -> Call -> Outgoing voice call settings and select "Do not allow VoLTE calls"
wad is this volte thing ah..??
1 week ago i reached HK i saw my note3 on top got this green/red arrows... then i enter shen zhen the thing disappear..
wad is it...?
disable it got wad use...? turn it on got wad use...?
bulldozer88
wad is it...?
Samsung people dont know these issues. Kept telling me delete apps. Then i think why need smartphone with no apps?
sgmem88
look like these issues are very new...volte...so they may not know...
but some apps do drain battery....
just solved android core apps drain battery issue on my phone...guess what caused it....it is Viber!
And this only happened after upgrade to kit kat 4.4.2 :s27:
seller4
wad is it...?
In the past, Voice Call is on 3G network and Data is on LTE network. Now with VoLTE, both Voice Call and Data are on LTE network
Read this if you want to know all the Geek about VoLTE.
What is VoLTE | Voice over LTE Tutorial | Radio-Electronics.com
hitme
Can't be viber
I holding on to 2 note 3.
The one with better battery life is the one with viber installed.
sgmem88
Can't be viber
I am not sure what cause the battery drain in Note 3 here....I am holding S4 Active... just want to bring across the point that apps do drain battery in some cases.
after upgrade to 4.4.2, Android Core Apps constantly used up at least 20% of my battery...after I disable most of settings in Viber, I don't see Android Core Apps in my battery usage list any more...
my guess is some apps may be using some android core apps or android system features/modules that make it hard to pin point to the apps that is the real culprit
djzilch
My note 3 also getting really poor battery these days
Use to can get 5 to 6 hour screen time, now more like 2 or 3 (4 if I'm really lucky and turn off lte)
bulldozer88
It cannot be apps. Because the apps are ok in Singapore and the phone only goes crazy whilst overseas.
Samsung said it is Viber. I use Viber extensively in SIngapore, Battery behaves normal.
Phone really goes haywire and SMS also doesnt function properly.
I hope Samsung can settle this. Suspect is the Kit Kat and VoLTE not working properly. Only suffer this during the latest update
renfred89
i went malaysia and my phone also die as fast as in singapore. not much difference...
