Note 3 Finally gets Lollipop
frozenjw
I've been on this update for a day.
I did a factory reset after updating.
So far battery life seems to be a little bit better than on kit kat.
Software has no issues so far and is noticeably smoother than kit kat.
newcell
Hi, any improvement on cam app? TIA
piggy1986
didn't do a factory reset so far so good for battery life and also phone no hang or anything will monitor and update :)
newcell
Camera mode is still the same. No difference from previous software.
Wow thanks, fast reply.
Note3 only dissatisfaction i have is the poor cam s/w. Since no improvement i rather keep kk.
tkl23786
No factory reset as well.
It has been over 24 hours since I have upgraded to Lollipop.
Battery drain is lesser now.
Everything is slightly faster and smoother.
Just need to get used to the stock color scheme and the new Lollipop features/layouts.
fathernature
Guys. Anyone experience prob with alarm clock. I can't seem to edit my alarm clock nor add new ones. Only can on or off the preset ones.
tkl23786
Using the stock app?
I have no problem with it. I can create new alarm and edit existing ones. In fact, my newly created alarm woke me up this morning at the set time.
Maybe try clearing cache and data of the app from the Application Manager?
tjkb230
It seems like the LED notification has stopped working. Charging red led is still working through. Anybody has this issue also?
tjkb230
Latest update: it seems like the led notification doesn't work in mute mode anymore. But isn't led should all the more work in mute because there is no sound and vibration? Getting weird here...
tkl23786
No LED issues for me too.
Red, Green, Blue, White all are working.
Even in "Vibrate", "Mute", "Sound" mode.
There are also "Always Interrupt" and "Priority Only" mode.
zapp!
Had the LED issue right after the upgrade process. Try resetting phone?
xd3vilx
I have the alarm clock problem at first, the clock app keep crashing when I want to set a new time. But I have since reset my phone and everything works. Love it. Battery seem to be better for me (maybe lesser apps now) and everything seem smooth. Like it.
