Note 3 Finally gets Lollipop
Ev0d3vil
One of my IR apps are not working after lollipop. Thought its my IR port issue, turns out the app just broke on lollipop.
Aetherion
After update my phone keep restarting if I turn on WiFi. Anyone knows of any solution other than probably hard reset?
tkl23786
I have no issues with WiFi.
Have you tried to forget the network and re-connect?
Sometimes it helps...
buibuisnail
i'm so freaking going mad. after upgrade, the side panel can only be called out by a long press. i want it to stay permanent on screen & move it around also. can't seem to find the options for it, can anyone help?
lxb_70
huh? u mean the multi window tab no longer appear on the home screen? have to long press the back button to activate it?
tkl23786
Yes, you have to long press "Back" button to bring out the multi-window function.
tjkb230
for certain apps that supports multiscreen function, you can slide diagonally down from the top left or top right corner when the app is fully opened, to activate multi-window, just that it will not cascade half-half so nicely.
buibuisnail
yes, this part i know. but before e upgrade u could manually enable/disable it to display there perm. now seems unable to do so, anyone found e solution yet?
OPEL184
Hi,
After upgrading, my s-pen dont seems to work. Anyone has this issue? Any experts solutions?
I mean, when you press the button at the side of s-pen, the scrap book box didnt pop out
lxb_70
guys, where does all the widget goes to? cannot find :(
edit: got it... :D
so far so good for my lollipop update, s pen function no prob, led light no prob... *keep finger crossed*
howdidoo
Played with mine and so happy as of now.. I had couple of nasty bugs removed from earlier versions.. Battery improvement and looks like a fresh life for my Sep2013 phone. No problem like couple of you mentioned here like LED or Alarm.. Just had error msgs twice that my Touchwiz has stopped working but resumed as usual immediately. I have not done Factory reset as lazy to backup & setup again. Going to use this phone for couple of months more maybe until Sep2015 and so no complaints.
tkl23786
Hi,
Have you checked the S Pen settings?
Under Pen Detachment, there is a Detachment Options
Make sure is Air Command, not None.
This will automatically launch the Air Command and you can perform the Scrap Book function without having the ned to press the S Pen.
By the way, the Air Command has been changed to look more like Note 4 now.
skywalker1110
Hi My phone having the same thing, S pen cannot work on screen short. :s11::s22:
Can someone help us. I can't work without it. Very sian...
Thank you
mister38
after upgraded to lollipop let it installed whatever it popup after all settle do a restart it helps..
skywalker1110
Hi bro and sis, need some advise from you guys. after upgrading, i can't in put group ring tone, alarm tone. why like that. Are you guy having this problem. :)
