[Official] Cree Flashlights Interest Group
Citiguy
Nitecore HC50 is good choice. I almost wanted to get one too. Wait till I get my helmet first. Haha.
Products sold by your link are over-priced...
kineticworks007, thanks for your comments. Yes, I realised that now, AFTER purchasing the headlamp...
kineticworks007
Kill enemy with 68,000 lumens? LoL
Blazing Light Bazookas - The Dogstar Portable LED Searchlight Packs Some Serious Power (GALLERY)
kineticworks007
I believe they are reported on candlepowerforums long ago. These cheap 18650s are prone to reliability issue, exaggerate capacity, fake cells and even explosion.
Sorry for sounding a little clueless about this, but may I know why? Thanks. :)
radiancez567
Many UltraFires 18650 batteries are fakes. Just google "Ultrafire fakes", and you get plenty of readings. If you ever take off those battery wrappers, most won't match each other (low quality cells sourced from everywhere, and re-packaged). Those that advertised 3000mAh, or even 4000mAh, are in actual fact less than 1000mAh in some cases.
Ye_Rongtian
Get Panasonic cells and you will be fine. Panasonic is one of the cheapest reliable one.
hairil
I see. Thanks for the head-up!
I'm using EagleTac 18650s for my Fenix PD35, so I guess they'll be alright. :)
kineticworks007
EagleTac 3400mAh(grn/white) 18650 is actually Panasonic cell under the wrapper with their own protection circuit. Yes, you are safe using EagleTac.
Citiguy
kineticworks007, why do 18650 batteries comes with flat top and button top?
kineticworks007
18650s are used in number of applications. They are commonly found inside notebook battery pack.
credit: csshih CPF
I believe flat-top will help to reduce the spacing in between the batteries, since their anodes and cathodes are usually soldered together.
Another reason is because these OEM flat-tops are also repackage into other brand names. With their own protection circuits included in it.
Correct me if I am wrong :)
OEM batteries are usually flat-top and unprotected, because there will be separate controller to manage charging and discharging issues.
Note: Some flashlight accept both button and flat top, but others do not. This is usually due to the contact point design or physical length of the 18650.
