[Official] DVB-T2 USB/PCI-E/PCI TV Tuner Thread
Mike_Lim
So i took the card for a run and it seems that issues are surfacing again.
May i ask, those using the 6281 and running in T2 mode, what driver version are you guys using?
Not sure if this helps.
Also got 6281 recently (received it on Tuesday) and running in DVB-C mode.
TBSViewer does not detect card, device is listed in Windows 7 Device Manager.
Resolved it by downloading the TBSViewer version from TBS Download Center-Update the Latest Window & Linux Driver
hwsinn
What problems do u have now? Still the issue with "unable to find available capture device"?
Using driver version 1.0.0.5 and 1.0.0.6 the tuners still keep crashing awhile after a recording.
I already changed a pcie slot to test as well. So its either driver or software issue. Now i am trying to source for another recording software that supports dual recording to test it out
As for drivers, I would like to hear what version are u guys using.
Trying doing a overlapping recording on a different frequency. Eg 10 to 1020 and 1010 to 1030 and do another overlapping recording probably 4 hours later to see if it still works. Sometimes i can get 4 recordings but later, i will not be able to access one tuner again
EDIT: im running on 1.0.0.5 and the latest NPVR. I have a recording for 118 at 7.30pm and the 9pm show. 118 recorded on tuner A but the 9pm show records on tuner B. I am pretty sure if i were to use tuner A specifically, it will say it cannot be started again.
hwsinn
So i went to use TBSViewer as well. Seems like the tuners did not hang or crash.
So i went to explore the features. The recording function has a checkbox for recording weekly on certain days but cannot be checked. Means i have to go in and key the schedule one by one lol. The data for the current show is also wrong. This is a small matter compared to the recording problem
Mike_Lim
TBSViewer is OEM version of DVB Viewer.
Maybe can try DVB Viewer Pro
Feature comparison at DVB viewer - Features
precise
Just received my card. Installed DVB-T2 drivers. TBS Viewer was like your case, cannot find devices. Uninstall TBS viewer, restarted the PC, re-install TBS viewer and presto! It works.
precise
Realised that recording HDTV in .TS format creates huge file. And it cannot be played directly onto my TV which reads .MPG format. Anybody know any recording software that can record directly into MPG format without going thru' conversion from .TS to .MPG.
Has been researching for the past 2 hours and did not find any. Most people say it is not possible to record in .MPG since the broadcast is stream in HD format. So .TS is the only recording format.
@lvyzy
Anyone managed to get the remote controller for the TBS 5220 USB DVB-T2/T/C working? Any specified setting to be done or any driver to be installed to use the remote controller?
I have no problem watching all the HD channels but cannot use the remote controller, I am using ProgDVB and Win 7 x64 OS.
Just received my TBS5220. Having the same issue as well.
Anyone got the remote control working out of the box?
hwsinn
Thats because broadcasts are usually in .ts format aka transport stream. I vaguely remember the reason being able to multiplex multiple streams.
anyways to answer your question, you can either transcode the video or demux the video and audio stream and mux it to a format of your choice. Since the HD streams are H.264, and you want a .mpg file, you probably need to transcode. Maybe you wanna check if your player supports H264 in .mp4 container?
morgankell
hey bros, i just brought 2 TBS 5520. With the latest 1.006 drivers, I keep getting error messages with the tuners. The tuners are detected but not available (in device manager, the tuners show exclamation marks; further checkling shows message of no enough api resources). In addition, it causes my other usb ports not to detect my wireless dongles.
There is nothing wrong with my system (window 8.1 with media center). After I swapped in my parent's htpc pctv 292e, all problems disappeared. The problem repeats itself in my parent's pc when I tried the TBS 5520 in my parents HTPC.
any bro can shed light on this? I think its poorly written drivers. I suspect is the 1.006 drivers, anyone has the 1.005?
LxIxVxE
Senior Mentor
have a TBS 5220 for almost a year now, so far so good
drivers 1.0.0.5 and 1.0.0.6 both works fine, now using latest 1.0.0.7, also no problem
but using win 7 x64, dun have 8.1 to try out for u
u may wanna update drivers for ur wireless adapter too
if u have not done so, test tuners and wireless adapter on other usb ports as well
LxIxVxE
Senior Mentor
problem solved already? :s11:
anyway, 6281 (using drivers 1.0.0.6 now) works fine with NPVR
even with a combination of several TBS tuners and hauppauge tuners recording whole day with NPVR, also dun have any tuner crashing problem like urs
LxIxVxE
Senior Mentor
juz an update on what T2 tuners u can get at SLS
Hauppauge 292E USB $99
Hauppauge 1975 USB $189
Hauppauge 2215 PCI-e $189
price from cybermind, dun noe where cheapest
Do not buy avermedia T2 products at the momemt
morgankell
LxIxVxE bro, thanks for the reply.
After much painful experimentation, I think I isolated the problem to 1 of the 2 tuners. There is nothing wrong with my other hardware, they happily co exist with my other stuff.
Most likely Ill rma the tuner (any idea if the rma process is painfree?) I already wasted 1 day reinstalling the OS, jumping between systems, changing usb ports, etc etc... :(
So far I used the TBS 6281 (pain-free, never tried the dvb-c driver though), TBS 5520 USb (pain plus plus but could be a odd damaged 5520), hauppauge 292e (pain-free once I found the drivers, I had to rma my 290e to get these)
LxIxVxE
Senior Mentor
have been buying TBS tuners for the past 3 years, all of them still working great, no experience with the RMA
but it should be pretty straight forward, create RMA online or email them for RMA, then follow the instructions to send back the item
hwsinn just RMA his 6281 not long ago, think he got back a new card quite fast
but he is having same problem with the new card, so it might be user related problem instead of a bad card
if u very sure one of ur 5220 is bad, then proceed with ur RMA
cwtanz
You can get the PCTV292e from SLS (e.g. Cybermind). Good hardware but the PCTV software is buggy. Keeps crashing when my PC goes to sleep. Have to reboot pc to run TV program again. Read other similar reviews on Amazon. Best to use another software like Windows Media Centre, etc. Enabling WMC invalidated my Windows Code Activation but thats another story...
I think Hauppauge winTV software is better but no drivers to make it work with the 292e.
es0teric
So you will recommend TBS5220 with using the antenna?
LxIxVxE
Senior Mentor
from oct or nov till now u haven't bought ur tuner? :s11:
early 2014, TBS is the only choice lor
but now, got more choices to choose
just like the geniatech T230 from aliexpress
now only abt US$22, can get 3 pcs for the price of 1 hauppauge 292e
still got a few brands from other part of the world, might not be cheap to get
just get any brand u like as long as it supports T2 V1.3.1
cheap or expensive, basically they will give u same video quality as long as u have good signal
es0teric
Yes, I haven't got any. At least now you mentioned got more choices compare to oct/nov with no choice.
I just hope to buy one in local. Afraid online later got lost plus in previous page some mentioned the frequency is not that good so thought wait for a while.
I am currently using old tv card, analog PCI type. But don't know why there are a lot of noise compare to last time even though I use splitter for internet and PCI tv card.
Btw, it is US$45 not US$22?
http://www.aliexpress.com/store/pro...T2-DVB-T-USB-TV-Stick/1263392_1857742736.html
Kiwi8
Deluxe Member
Any other options than TBS if I wanna buy dual or quad DVB-C cards?
libertizer
i bought my mygica T230 via this url:
dvb t2 receiver GENIATECH MyGica USB TV Stick T230/T220A DVB T2 Tuner DVB C/DVB T for Russia, Thailand, Colombia, Europe-in Satellite TV Receiver from Consumer Electronics on Aliexpress.com | Alibaba Group
I am currently facing bsod issue with the t230 in windows 7 64bit with APC_INDEX_MISMATCH. Windows will crash when using tv software such as dvbviewer. The bundled totalmedia 3.5 is fine though, but I cant receive HD5 via dvb-c.
Feedback to the support and they be sending me an updated driver. Hopefully it will solve the issue.
