[Official] DVB-T2 USB/PCI-E/PCI TV Tuner Thread
Kiwi8
Deluxe Member
Yes I got this one.
If u want u shouldn't have to spend more than USD 40 for it... I bought from eBay.
Anyway, this stick's DVB-T2 isn't v1.3.1 compliant, so u can't receive MediaCorp's DVB-T2 channels. The DVB-C reception still works though, so u can connect a cable from the StarHub antenna box to this stick to receive DVB-C channels.
sacredrays
ok thanks. my comp no where near the cable point.. lol. looks like have to find other stick then.
radiancez567
Received TBS5220.
How do I set it up?
I plugged it into USB port, attached the provided antenna, installed drivers for it, and used TBSViewer to scan range, but there's no channel found...
EDIT: I managed to receive only two channels, Channel 8 and Vasantham. How to receive the others? Need better antenna?
EDIT2: Managed to receive the channels already :) I need to place antenna near window somehow.
PoloBoiBoi
Received TBS5220.
How do I set it up?
where do you live?
if your area is not yet covered with indoor reception , then you have to stick the antenna out of your window for outdoor reception
Mike_Lim
radiancez567
sacredrays
i see from amazon got a lot of dvb-t2 usb sticks selling from 20 usd onwards leh.. which one can which one cannot? the specs never write the version...
PoloBoiBoi
thats the problem ... difficult or impossible to tell without explicitly stated
you wanna buy and tell us whether it works?
FatalityV
If you really want to cut costs until like that, then you buy arleady tell us lor..
If the specs never write, you pm buyer no response, we also won't know unless got people use before..
es0teric
Received TBS5220.
How do I set it up?
So have your issue settle? I thought this model don't have problem.
Now I need to reconsider.
es0teric
Raining day I dunno yet. But I can receive Channel 8, Channel 5, Vasantham, Suria, and Channel U, CNA, Okto.
ok, then I can invest liao. But my room is towards the corridor. Wonder where to buy the connector for the TV wall socket instead.
Btw, which level you stay at?
hwsinn
I don't think it's due to weak signal strength at my location because I could receive all DVB-T2 channels clearly with a Sinho set-top box from Aliexpress + simple antenna like this:
hi, is this antenna good and where can i get this. Need to get a antenna and the leaf antenna is too big.
I recently saw that the free set top box provided by M1 has a similar antenna
chong
It's just a cheapo antenna that was passed to me, origins unknown. I put it at my room window facing an open area so probably that's why it can catch so many channels.
I think there's many similar looking ones on ebay.
FatalityV
This model has no issue.. I am using it just fine.
The issue is whether you are putting it int he right spot, or your house got reception.
If your house no reception you will need to use DVB-C instead. Basically instead of using an antenna connect it to your house the wall socket./
