FatalityV
- Aug 8, 2009
ya.. where to get hdmi capture card ?
I personally never use so I am unsure if compatible or not.
But I believe I saw a hdmi capture card selling on tbs before.
ebay & aliexpress~ search YK762H PCI-E HDMI Video Capture~
hdmi capture card can only record in realtime, no schedule recording which is kinda defect the purpose if u using it as time recorder~
btw, tbs got sell DVB-T2/C card with CI slot, im not sure whether starhub's card works on their CAM module or not~ if it able then you will hv full control~![]()
I think Hauppauge also has a HDMI capture card called Colossus rite?
But when using HDMI capture card, do be sure to check first that the HDMI output that u intend to capture from, is not encrypted (HDCP protection to prevent capture).
I recently bought the AVerTV Hybrid Volar T2 (http://avertv.avermedia.com/product/ProductDetail.aspx?Id=582)
I scan the digital tv channels and I have no problem watching CNA.
But when I try to watch the HD channels like Ch 5/8, the picture looks ok (maybe pixellise a bit here and there) but the audio is horribly distorted. It is as if you hear audio playback slow down 10-20x like that.
I am using the stock antenna that came with the box.
I am using the latest driver/software downloaded from their website mentioned above.
What did I miss?![]()
switch audio
there should be 2 audio channels, just switch to the other one
Do you use this model too? Can you tell me the steps to switch channel in the software?
I tried to dig through the menu settings... no luck.
whee. finally got my hands on this wonderful tuner.
using dvbviewer, i am only getting 83% signal strength. is this normal?
Just like your WiFi and 4g
You won't get 100% signal strength unless you are within line of sight of the transmission
But the good thing about digital signal is that you still can receive well enough as long as the strength isn't very low
Don't know whether want to go ahead getting this TBS5281 DVB-T2/T/C Dual Tuner TV USB Box or not
The 20% discount still ongoing at the moment.
Anyone bought this and your comments pls![]()
