Thanks! By hotel effect i basically meant strong spotlights (7-12V). I actually don't need multi coloured lights - just need them to be dimmable! The part about this was just to show why I will likely be going with dumb bulbs and smart bulbs are out of the equation.
Anyway, I think the main question I have now is about the switches I can use in Singapore.. regardless of the types of lights I eventually get (dumb bulbs), it should work right? Oh and the other thing is it has to be able to connect to my GoogleHome..
I'm looking at smart switches for at least my dining/living/master bedroom area, and if it is within budget then add on for bathrooms and 2 other bedrooms.
Would appreciate any recommendation!
Ok I'll talk on the bulb part. If you just need dimmer features, you can consider the Philips existing range of smart bulbs which run on ZigBee (requires a hub), or if you want WiFi controlled without a hub, consider the
Lifx bulb. Both can connect to your Google Home directly. And yes, smart switches will work with your dumb lights.
As for the smart switch, you will need to decide how you want the switches to work. Do you want them to run on Z-Wave? ZigBee? Or plain WiFi? The prices vary, with WiFi light switches being bigger in variety, cheaper, but you need to allow cloud access, and if their cloud server is down you might not be able to control the lights via voice.
If you want to have more local control, you can control going Z-Wave or ZigBee light switches, but be aware both types you need a hub to work with them, like SmartThings, Hubitat, etc. These tend to run on their own band except Zigbee so no worries about adding a lot of things to your WiFi and you can control them locally.
I can't recommend the switch as there is a wide range and type with budget, but you can go read up ZigBee/Z-Wave if these interest you.
