waterfoe
Lutron lighting control for the Singapore market only come in the form of Homework QS.
Lutron does support 240v, just that it more of a centralized lighting control system.
Congrats! I'll try to answer in the simplest way possible.
  1. If you intend to have "hotel effect", I assume you mean multi coloured light with brightness adjustment as well? Can you further explain what you mean by "hotel effect" so we are on the same level of understanding?
  2. Lutron smart switches is not available in 240V.
I think it's better you explain what effect you are trying to get so can recommend. I can tell you smart switches do not cost that much.
Vulpix
Moderator
Moderator
Oh thank you. When I emailed Lutron, they said they did not have the 240v equivalent of their US products which was very disappointing to me.
Vulpix
Moderator
Moderator
Thanks again for the advice. Seems like both are similar to how i treat alexa and google home - either works :)
Could you help to throw out some names of smart switches? So that I can get started on those and move along from there. Before i posted here i was also considering Kasa and Belkin Wemo smart switches but am not sure what to look out for to know whether it works for Singapore!
Also, what make you choose Hubitat over something like Fibaro?
Very hard to give you switch names lah. If you can tell me which protocol you want like z-wave, zigbee or wifi, I can tell you a few brands for your preferred protocol.
I picked Hubitat because it's cheap and very powerful if you willing to learn how to use it, plus the full suite of customization calls out to me. :s13: You can control both Zigbee and z-wave devices, plus there is a very active developer community for this product. Fibaro is very nice if you want to only use z-wave stuff and want something easy to use.
waterfoe
I believe the Lutron system you are referring to are mainly RA2 or Caseta range of products. All the wireless system from Lutron currently only support 110v.
Early part of the year, Lutron has expanded RA2 into the Europe market. The setup is abit different. All the lighting circuits will need to install a lighting control module and control via a battery operated keypad (something similar to the hue remote).
As for Homework QS, it an integrated system, this is where you can choose many different keypad design (eg seetouch, palladiom series) etc... But the downside is that your house will need to re-wire everything (driving up the cost). The lighting keypads are all connected via an automation cable, all your lighting circuits will need to route to the DB.
Such system are mainly used in the landed segment and also some of older and bigger condo units. Wireless solution will not be so ideal....
Vulpix
Moderator
Moderator
Ugh that doesn't really sound worth it for our small pigeon holes. I think I'll just stick to cheapo China z-wave light switches.
viix
Anyone knows if Xiaomi Aqara curtain motor can be repurposed to slide my toilet glass door open and close? I'm guessing it requires about 1-3kg of horizontal pushing force? I heard the motor stops when it detects resistance?
The motor requires a specific track system that's cannot be modified to slide glass doors.. besides, the motor doesnt have the torque required and the rail system slips on friction and stops.
Sounds chim. Buy online or challenger??
Challenger has the arlo.. everything else, amazon, q10 etc..
Hi guys, I'm a new home owner trying to build up my own smart home, and have a couple of questions on smart lighting.
My ID has convinced me to get certain lights that give the "hotel" effect - unfortunately that means I can't go down the smart bulbs route - these lights come in the full set (bulb, driver, casing).
I'm looking at smart switches now but his vendor is recommending smart switches that cost around $200 per piece (heavily marked up I'm guessing).
Read a couple of articles (googled best smart switches) and Lutron sounds reliable. However, the lighting shop is recommending I purchase 1 switch first for them to test if it is compatible with their lights.
Anyone knows if these Lutron switches should be reliable or have used other smart switches that work? Am afraid of the incompatibility since this is a US brand and is meant to work with 110V?
Sounds like me 2 years back..
Make sure your ID is going with GU10 lights, not MR16 with the driver. I also did spotlights to have more dark spots around the house for the supposed hotel effect. With GU10, u have the option to install the cheaper milight or the more ex hues. If MR16, you are limited.
The Gu10 cases are easily available so don't listen to your ID limiting your choices with the mr16 format.
Tell them you want GU10, make sure the fixture is deep enough to fit 72mm bulb (see this). I use hue bulbs as benchmark because if you can fit hue, every other smart bulbs can fit.
You also dont need to go to his vendor, if 200 per switch, you are better off going straight to automate asia and they can advise better. I reckon you just bring your floor plan to them and have a no obligation consult.
I believe your ID is recommending you some form of dimmable circuit, which is why the light shop ask to bring it. I can honestly say save the trouble as I went through that phase 2 years back. Here's what I did,
Have your chandeliers on smart switch, you can have a dimmer module in between if u need to adjust the brightness but no smart dimming capability.. those dimmers easily available to limit the brightness.
Cove area install a socket, don't fix it permanent so u can install smart lights later on, if no need at least option is there. can remove if you using normal led strips with drivers. This is so they make it deep enough to hide the socket and not have a shadow.
Light fixtures use those with e14 or e27 platform if you want smart lights. Ie those fancy danish design lights.. Even my hood also has e14 color bulbs.
Spotlights use gu10, dont use mr14. If not getting smart bulb first, you can easily started with those 3 step dimmable lights before converting all the hue and milight.
After thinking very long, I finally bought the Hubitat. Can't wait for it to ship. :D
GXGX! please post your experience here!
kpo kia
Does anyone knows how to create a poll?
Can we vote on the top few popular household gadgets that we would DEFINITELY BUY for our smart home? If buy all, will definitely burst my budget. :(
1. Lights
2. IP Camera
3. Curtain
4. Aircon
5. Voice Assistance
6. Door Lock
7. Bath tub/ Shower
8. Air Purifier
9. Any others?
yamashita
Moderator
Moderator
Is there zigbee/zwave device that can learn and send RF 433Mhz signal? There is similar offering for Broadlink but looking into zigbee/zwave which I can make use of my existing controller.
I am thinking of home automation scenes where I can control my front gate which is currently controlled by remote control on RF 433 Mhz.
viix
1. Lights
2. IP Camera
3. Curtain
4. Aircon
5. Voice Assistance
6. Door Lock
7. Bath tub/ Shower
8. Air Purifier
9. Any others?
Depends on your priorities? I have a paraplegic family member.. smart home is more of an accessibility purpose than a want. so all except 7 & 8 is priority.
viix
Dont recall seeing one as zwave and zigbee usually have a command class signal to send. Don't think there is a market for a zigbee or zwave to RF just to send 1 command so it's usually a wifi based RF bridge..
You can probably hack together a FIBARO Smart Implant with a cheap RF keyfob but the cost doesnt make sense when a broadlink rmpro or sonoff RF bridge is so cheap..
porker997
A poll would be a good idea since so many items out there in the market. Don't know how to start one though.
What about main door digital locks gents? Any recommendations? I'm thinking of going with Yale but so many models in there. Also any vendor to recommend? Thanks again.
pustefix
I don't see why a poll is useful as different people have different priorities, knowing something is popular or not shouldn't affect your decision. What you need is a list of possible automation ideas.
For digital lock, I have a non-smart one. Since most digital lock will auto lock when closed, the only need for smart one is to remotely open the lock which I don't see a use case for.
waterfoe
Centralized lighting system is indeed not very common in apartments unless the size of the apartment is huge like 1500 sqft and the interior structure are made of concrete/brick.
It hard to even compare an integrated system vs DIY.... You need to see an actual setup to really compare. You will also be surprise the cost is really not that significant higher.
End of the day, it also depend on what you really want to achieve.
I used to have a DIY setup but migrated to a integrated system so able to see the differences and also on the cost perspective.
Food for thoughts.....
viix
The only limitation to centralised systems are the scalability and interoperability with newer IOT technologies.. plus side is less tinkering required to make things work.
Whilst the cost perspective may not be huge at the initial phase for a small apartment of similar setup, the cost adds up once you decide to add additional functions to such a integrated setup.. not to mention labour cost to have specialised technicians to come install/upgrade/troubleshoot it.
waterfoe
When you mentioned scalability, think about it this way, when u already have that many lightings circuits for your house, what are the chances you will increase your lighting circuits from maybe 15 to 20 circuits?
In the first place if you have provision extra lighting circuits in a centralized system. You can actually expand and assigned extra circuits to the keypad.
For illustration purposes:
If you currently using a MCO 4 gang keypad, that will mean having 4 lighting loads connected to the keypad. If by any chance, you are going to have another 2 more gang for the room, so what can you do:
1. Hack the wall and place another MCO 2 gang keypad
2. Maybe adding 2 more module in the false ceiling to control the respective light (That is provided, you have false ceiling where the new BTO and condo having miserable ceiling height)
For an integrated system, the keypads come in many different configuration. You can always assigned the button to respond differently. There are keypad in the market than can config from 1 button to 10 buttons based on the need arise. This alone, i believe is more dynamic.
Not forgetting the above mentioned purely for on/off switch. How about dimmable circuits? I do understand we can use smart bulb like Hue and LIFX, if you put everything into context, Maybe having a lighting fixture that is able to fit 2 GU10 bulbs.... So a living room having 2x2 lighting configuration.
Cost:
4x Lighting fixture = $50 each x 4 = $200
8x Hue Gu10 Bulb = $49 each x 8 = $392 (assuming no discount)
Total = $592
vs
4x Lighting fixture = $50 x 4 = $200
8x Dimmable Gu10 Bulb = $10 x 8 = $80
Total = $280
How about using a DIY dimmable keypad? So far i see is MCO dimmable module which you can only control 1 dimmable circuit (Maybe i havent seen enough but for now i only saw that) So for a living room with 2 dimmable circuits u need to have 2 keypads, factoring the rest of the house, you end up with more than 1 keypads in 1 particular area. So is this sort of design acceptable?
Vulpix
Moderator
Moderator
Is there a z-wave module I can get to control dumb TDK fan and lights? I can't seem to find a solution. I wonder if the best way is to buy a fan with an E27 bulb so I can just use it.
viix
Cost:
Total = $592
vs
Total = $280
Not so much the standard fixtures in terms of scalability. More like expanding its capability (ie. adding sensors, control devices, connecting to other IOT APIs etc..) with an open system, one can reduce the amount of physical control hardware and use sensors/data/presences with already present devices and data to integrate functions.. say I want lumen based light switching, or weather base climate control..
basically putting the smart and automation together..
Most of the open platforms provide connections to external services like ifttt but I’m not too sure about intergrated systems like the gira and control4?
And with more user base onboard with open platforms, there’s definitely more development there than legacy systems..
Just on off? Fibaro smart implant maybe?
Inediblebulk
Anybody managed to link Google home to Mi home? I got my stuff on the china server and 1 roborock on the sg server. Somehow Google home only can sync with the Singapore server and only can see the roborock
