tian800
For the neutral wire, what is the correct size to pull? 2.5mm.sq?
Does the electrician need to calculate the load of that circuit to prevent overloading of neutral wire?
pustefix
Gonna get a new house soon so thinking of automation. For now I'm using a broadlink rm mini coupled with a few yeelights, with Google home the center of everything. I was considering of just using broadlink IR switches, but I realized that they do not report the state of the switches. So my next alternative will be to use a hub right?
The answer to your question is what level of automation do you need? Let's say your rm mini is connected to your TV and there is Yeelight in your living room. You can set up routines in GH to turn on both your TV and light at the same time. You can even schedule this routine to run at certain times.
Then you add a broadlink IR switch to another light. You can add this to the same routine so that now you turn on 3 devices at the same time. If this is all you need, then NO, you don't need a hub.
What happen if you wanted to add a motion sensor and you wanted to turn on the 3 devices when motion is detected? Your current setup will not be able to achieve this, that's when you need a hub. The hub will integrate devices from different company and set more complex automation rules.
Even if you don't add the motion sensor but if your automation needs are more complex than to turn on/off devices together or schedule them, then you will also need a hub. E.g. when the light is turned on, set it to different brightness and color temperature depending on the time of day.
Vulpix
Moderator
Moderator
Hubitat has native support for Neo Coolcam :)
Not sure if anyone interested, but I managed to secure a deal directly from Coolcam for the light switch. US$11 for 1 gang, US$12 for 2 gang for the Z-Wave EU version. Shipping gonna be US$5x but this seems like a fairly good deal. Would anyone be interested?
porker997
Good points. I think for longer term usage, I am prepared to invest into a hub. Looking at the Homey, seems to be versatile across protocols and good reviews so far.
On bathroom automation, thanks for the inputs. I have one more scenario to think about, what happens if you go into the bathroom just to wash hands/brush teeth and the bathroom door is left open? I am assuming the door sensor is only activated on full open or full close. In that scenario, one would only have the motion sensor to keep the lights on?
Cheers
Vulpix
Moderator
Moderator
Cheers
Why not consider Hubitat as well?
viix
I'm interested in their zwave flood sensor and v2 motion sensor. What deal can you get for these?
pustefix
These are my automation rules for the bathroom:
- when motion is detected, turn on light.
- when motion is off for 2 minutes and door is opened, turn off light.
- when door transition from closed to opened, turn off light.
Vulpix
Moderator
Moderator
I didn't ask as I will need a fairly high quantity to get a good deal for those.
yamashita
Moderator
Moderator
Seems like a good deal, considering it's selling at SGD33+.
I would have tapped on your order, but already have enough switches :p
viix
Finding the ideal placement for motion sensor would be the best and one may not need the door contact sensor. I shifted my sensors around to find where works best. Depending on your layout, I find the best location for my situation was above the tap area pointing towards the toilet bowl and shower. This detected all my movement except walking past outside it.
I've had it before above the shower door looking down but it detected if I walked past, on top of toilet bowl but it missed if I was showering..
Vulpix
Moderator
Moderator
:s13: I still trying to calculate how many light switches I need for my new home.
porker997
I found this super slim door motion sensor from Amazon US using Z-Wave plus. It's called Sensative.
I like it but a bit pricey. I can't seem to copy links here given my post count.
Vulpix
Moderator
Moderator
You on z-wave US frequency for your devices?
viix
the sensative strip can be purchased locally but for the price, can get 4-5 aqara contact sensor.. besides the aqara one not that visible after awhile 😂
porker997
Thanks for this. Yes, h4sh carries the products locally. Great, can save on shipping. Planning to get a few items from them. Seems well stocked.
