shacboi
Finally got a 1-gang version of the Minitiger switch. Installed without capacitor for a fluorescent tube light. Paired with the Tuyasmart App.
u manage to installed the non-neutral wire switch without capacitor n no flicker issue ?
Not sure how low the watts or what den it will flicker ? hm.m.m...
but non-neutral & using Smart Life / Tuya app is awesome!:s12:
baineteo
HA, openHAB, Smartthings, Hubitat etc
Just to make sure I am understanding it correctly, the above mentioned are software that are able to talk to different hardware and gateways platforms. Is my understanding correctly?
I just recently also read about Tuya and SmartLife app, and potentially can integrate with aqara. Is that correct, or is it just another SW platform? I can’t seems to find a “tuya” gateway, but I understand it to be a form of zigbee.
0x0011
Hi all,
Is it possible to add an infrared accessory (which is not listed in the app) and link it with Xiaomi mijia IR blaster?
zoneguard
HA and openHAB are software. Hubitat and Smartthings are software but have their own gateways (hardware).
Tuya is an ecosystem where vendors that sell smart switches/devices/plugs/sensors/fan controllers/appliances/cameras don't develop their own apps and use the Tuya family of apps/cloud instead. Tuya has support for various protocols: Wifi/Zigbee/Bluetooth. They are basically a competitor to Xiaomi Aqara. There is now a Tuya Zigbee gateway, google for the brand Zemismart. They even have 86 sized Zigbee wall switches non-neutral.
zoneguard
I had some issues and have temporarily removed the switch for now. Will find an opportunity to install capacitor at another time.
shacboi
I communicate wit the seller, he say must install the capacitor on lef bulb else "cannot work".
Not sure anybody try alrdy without capacitor, the issue I'm thinking is it cause led Watts too low, or what is the minimum Watts that can make the light stable without capacitor.
Think the seller dun really can answer that, need ownself trial and error liao.
Alwaysb
If I change whole house to smart switches, do I still need to install smart lights or it can control traditional lights?
I saw there smart wall socket as well.
Same here. I’m stuck with a few 3 gang, but i prefer the look and feel of the aqara switches. If I need to have a mix of aqara and say broadlink switches, how to integrate them?
Alwaysb
Hi, how much did you pay for neutral wiring? I am still trying to budget how it will cost for whole house
Dimensions (LxWxH): 41 x 36 x 17 mm. Same as Shelly 1.
I installed the Shelly 1 inside the ceiling LED casing.
noelsinggih
If no neutral, why can’t I get the state? I thought as long as there’s some power, the WiFi/zigbee model will be able to update its state?
Thanks for the input for Sonoff/Shelby, I don’t have the option to open up the ceiling anymore though. :(
Superbigfatdaddy
With smart light switch, you can control traditional lights as well, so you dun need to change to smart light bulb. Unless you want to change the colour of the light.
zoneguard
When switch is off, no current flows through switch and not possible to update state. The whole point of installing neutral wire is to allow current to flow through switch even when turned off as there is a return path for current through this neutral wire, rather than through the neutral wire at the lighting point.
Ap3s
I've connected xiaomi gateway, switches and sensors to Mi Home China server. I recently bought Mi Air Purifier 2S but it appears it can only connect to Singapore server (I created another mi account to validate thid). Is there any expert suggestion on how to connect the air purifier to China server? Thanks.
viix
Where and which seller did you purchase it from? Looking to get another as my 1st was SG server, but the second and current one on qoo10 connects to china server.. Looking to get for SG server..
nico-sg
wait for few months, I think Aqara announced few weeks back the release of a 3 gang switch
nico-sg
It really depends of your configuration (HDB. Condo, Concealed, Few switches gathered in one location,...) . For my case, I paid 120$ to pull the neutral wire to 1 location where there is now 3 aqara switches (2 gang each). The neutral was taken from the closest down light in the false ceiling, and the LEW managed to run it behind the existing cabinet. At the end, 2x 2cm holes at the back of the cabinet, no trunking, plus all the 3 switch rearranged (I had some weird configuration between lights in the dinning area and living area). Total: 2-3 hours of work for the LEW. Rest, I managed to do it myself for the common bathroom (taken the neutral from water heater, not supposed to work as they are supposed to be connected to 2 different area in the db box, but it worked in my case). There is now a motion sensor to swith on/off the light in the common bathroom. I also added one Aqara 2 gang in my kid's room (They wanted Xiaomi in their room!!), and pull the neutral wire from light in the corridor. They now have a wireless "pebble" pasted to their bed, to swith on/off lights. I also put the Xiaomi hub in their bedroom, so the they switch on the color light before sleeping, and it will automatically swith off after 15min.
No plan to add in the master bedroom as I already have a 2 way setup. Kitchen and the rest, no need, it will require too much work, and very little benefits.
My advise would be to select the switch to convert to SMART which will give you greater benefits.
Igene
Anyone tried those kinetic powered switch before? Save the hassle of wiring... But dunno how it works.
Vulpix
Moderator
Moderator
If anyone looking for smart fans, I recommend checking out PO Eco Fans. Got local office, around for very long. Checked out their fans, good quality, many pattern and configuration. Using smart life to control so works great with Google home or Alexa.
So far the fan can control speed (4 steps), brightness from 0-100 intensity via Google home too, only thing you cannot control at the moment is the light colour via Home. I believe this will be added to the fan eventually when smart life is updated. Really like the fans and quite strong, though not as strong as a KDK U60 at full speed.
Price is below 500 without installation cost, gonna be getting some when my new home is here.
