nico-sg
The line8 one is interesting. Let me know when you find out more as well, I am curious if it's per socket or can only switch on/off the entire strip.
As of now it s for the whole rack. Still, I will go with Line8 for my reno ;)
nico-sg
Hi,
I'm new to this home automation thingy. Was planning to buy Xiaomi Universal IR to automate aircon. May I know if I can use google home to perform its action ?
Not yet out of the box. As of now, you would need to have a raspberry PI with HA, and do the coding yourself if you want to integrate Alexa/Google home with Xiaomi product
BUT... BUT...
Xiaomi is working on both Google Home and Alexa Integration. You can follow their facebook page, they usually post some video/update about it
facebook.com/Aqara.Official/posts/569280537146164
nico-sg
Hi,
Has anybody make use of this product:
Original Xiaomi Aqara Two-way Module
lazada.sg/catalog/?q=Original+Xiaomi+Aqara+Two-way+Module&_keyori=ss&from=input&spm=a2o42.pdp.search.go.3cef19f00rjoYQ
It seems that it can be integrated to aircon unit? how? I am not sure of the benefits of this product? Is it an alternative for you to keep your physical / standard switch non-neutral, instead of swapping them to smart & neutral switch?
In the pictures they show some integration with aircon, but not able to find clear detail on how to integrate and what it can do. Any help? Thanks!
Aircon remotes sends a combined code so it's not incremental. You have to store preset settings (ie 25c, fan speed 2, rotating vane) to the homey broadlink app.
Homey and aqara can recognise the double and single press.
For homey I set sequential double press to activate something else also..
Their smart aircon not really smart. Just display a temp and send information to your devices and allow for wireless control. Thermostat wise is the same as the dumb aircon.
The most reasonable so far is ambiclimate but for the price, the supposed machine learning doesn't add much value. I just DIY using a broadlink mini, a temp and humidity sensor and some simple logic flows in homey.
Can, by right not supposed to but if you see the DB box, all the neutral are looped to one. No breakers for each line since it's not double pole switched..
aero_sg
Hi,
This device is to power on/off appliances. I don't think it is useful to control aircon. If you are planning to control your aircon, this one suits better:
aliexpress com/af/xiaomi-mijia-universal-remote.html
(Sorry, just realized somebody else also mentioned the same, I think it is quite easy to automate stuff by using this. As far as I know you can set timer or you can conditionally start aircon based other events by using Mi Home)
and you are right currently this cannot be used with Google Home :(
Jurong640
Is all aqara related sensors and switches only available on China server?
I'm asking this is because I intending to get aqara smart wall switches and heard that it only work on china server. To do that, I also need to get the correct Xiaomi Gateway Hub.
I have all my other Yeelights and xiaomi air purifier on SG server, hence I want to know. If I were to get Xiaomi Gateway Hub and Aqara switches, I will need to switch all my yeelights and air purifiers to China server.
Thanks
baineteo
Could be a faulty switch..
Yes, most likely. The shopper seller has gladly agreed to send a replacement !
By the way, I’m trying to find alternative apps to the Mi Home app for my mijia gateway without using additional hardware (for now). The Mi Home app is too simple and doesn’t provide enough options. No 3rd party hardware oesn’t seem to be possible, if I’m not wrong? Can I head out to get a Samsung SmartThings? Or other options?
Sensational
just wanna check if anybody has any smart home company that does smart home for a place that is going to undergo renovation? my electrician recommended this company called twobest international group and their demo seems not bad. but china company and wondering if anybody has any reviews for them.
or if there are any companies that do the same kind of service?
Vulpix
Moderator
Moderator
Make sure you ask what platform he is running on. Z-wave? Wifi? Zigbee? Proprietary frequency? And does it support the major voice assistants like Alexa or Google?
Sensational
yea he showed me the demo and google home all works.
as for the platform i need to check because he didn't say. the service include like syncing everything up to google home etc.
they will be doing some wiring concurrently with my home reno
Vulpix
Moderator
Moderator
Ehhhh. It's best you clarify. Imagine it's on some proprietary frequency/technology, and the company decides to close up. You'll be left with relics that you cannot change or super expensive accessories that you need to hunt on eBay. If it's the more common ones, at least even if company gone, you can do your own troubleshooting if something spoils.
Sensational
i see. okay can thanks thanks. will call and ask. he was just showing me all the demo stuff.
fyourlife
Just got my HDB, and will probably dive into the Aqara / Mijia ecosystem.
As I understand, it is zigbee driven, and I can still swap to another zigbee-based ecosystem in future if needed.
However, would like to check if the gateway needs to be centrally located so that all the switches can communicate to the gateway, or can it go from switch -> switch -> gateway?
Carol_88
The gateway controls the switches. Aqara g2 works as a gateway hub as well.
fyourlife
Ah just read more, its a mesh system so I don't need to put the gateway centrally in the house.
Anyone running Homey / Vera + Aqara? I am considering that as an option rather than using Aqara Gateway and MiHome
Vulpix
Moderator
Moderator
I don't think you should try to run homey + aqara, or any other non-xiaomi hub in general. A lot of it is very "hacky" as the Aqara switches do not comply to ZigBee 3.0, if the next revision of the Aqara switch got changes and the author of the module never update, you gonna have a lot of problems.
viix
Aqara and homey still ok since aqara is cheap. But do note the limitations of as mentioned by vulpix of it not being standard zigbee. The app in homey for aqara is built by the community so support will vary with the developer.
Like all smart switches, if the developer doesn't support it anymore, you can just use the old one but pray it doesn't spoil and if it does, it's still the same build version (as aqara sometimes updates the device ID which might break the connection). This is the same whether it's aqara or MCO on homey or Hubitat.
Pros and cons of community driven hubs..
Vulpix
Moderator
Moderator
I don't think that it's really a problem with community driven hubs, those Z-wave compliant switches work on any hub without any special drivers or anything. This is really a problem that exists on ZigBee a lot. It's not just Aqara, some other ZigBee products only can work with their own hub as seen in some smart home setups advertised locally. Was shocked when I heard about it, one super good example is IKEA, it's very troublesome to setup.
fyourlife
Thanks for the insights.
Do you have any recommendations on what ecosystem I should run instead of Aqara then? Singapore availability would be preferred. When I look on automate asia site, i think there's Aoetec, but it is about 3x the price for the wall mounted switches .
Google Home integration is a strong plus, but I understand that I can't really use Aqara gateway to connect to google home (or many devices are not supported)
Cheers
viix
Zwave also has secure channels which might not work across all hubs. Even if it’s Zwave compliant, the devices needs to support it to use all the functions else it’s just added as a basic device. It works but if you are anal like me not seeing the correct device type, it can be an eyesore in the app lol. But i agree it is less problematic than zigbee. With this compliance comes the price whereas zigbee is relatively cheaper..
Vulpix
Moderator
Moderator
I think for z-wave it's not really a huge issue as most of the basic profiles for light switches, curtain devices, etc all have a specific generic profile you can use on a proper z-wave hub.
