blue_yoghurt
No, just find out if got neutral anot. Open up 10 second can check already. Why want take risk spend more
Hmm, was thinking to get a handyman to install it for me because i wasn't very confident of the wiring, so i thought might be quite troublesome to ask him to come twice, once to inspect and once to install so I thought to get one that is more likely to work.
In the end decided to take your advice to open up to take a look. Was reading up on how to tell if there's a neutral wire, but my wires are all red. Hmm, from the looks of it they're all connected to two ports on the switch, so it's most probably no neutral wire correct?
Thanks!
viix
Thanks!
No neutral. Left is from the mains with one daisy chain to another light socket. Right is to the load. as a rule of thumb, most likely no neutral unless it's has a neon switch (those lighted switch for heater and washing machine/fridge etc)
Elon Jobs
I’m not sure what level of integration you’re referring to, but I just activated my Xiaomi robot vacuum cleaner to clean my house in the afternoon via voice command to my Google Home mini.
I thought XiaoMi can’t integrate with Google Home yet?
9N1Y9N1Y
Anyone using xiaomi door n window sensor? Wanted to set alert that each time door open or close to send notification to phone but it doesn't work (no alert send)
Endless09
What I’m referring to is the smart home automation such as using smart home hub to control Xiaomi sensors.
davi502
How did you configure? You tried to add the "send notifications to device" task or?
OptiRed
For sharing, Minitiger Wifi switch.
They have both Tuya and Ewelink app versions of the switch and neutral/no neutral versions. Interesting.
EU size but dimensions are 86 by 86mm.
Tuya has GH/Alexa support and local control (cloudless) is also. HA support is there for both cloud and cloudless versions.
May I know which version should I buy for SG use please?
Single Fire Line or
Null and Fire Line
I am new to this kind of things but was researching on Tuya and came across this thread.
Thank you :)
Alphas
If just a simple switch single fire will do. The red wire is the Live wire, make sure you know what you doing.
noname86
Hi guys,
I am interested in installing WiFi smart switches (non neutral) to be compatible with my Google Home devices. Any recommendations?
I saw that there is this GE smart switch on Amazon but I am not sure if it is compatible in Singapore. Any advice on it?
viix
Hi guys,
Amazon US? not compatible as theirs is different voltage and size.
viix
No hub can control sensors, but sensors can report to hubs.
for your question, Mi home is working with google home and alexa.
At the moment, only wifi devices are available directly within Google home.
For sensors, as they are zigbee devices. A compatible hub is required. Not sure about xiaomi but aqara hub should be working with google home. I dont use aqara hub so I'm not sure if the sensors connected to the hub is exposed to google anot..
In my case, aqara temperature sensors are exposed to Alexa via Homey and Hue Motion sensors are too via the hue bridge. So alexa can trigger based on the movement and I can ask alexa about the temps/humidity.
JJJ010101
hi guys.. can I say that if i'm not using any sensors (let's say i only want to use voice control), I can just do with Google home, and not use a Smart Hub?
maybe if in the future i wish to incorporate some sensors, then I add a smart hub? will that work?
viix
Think of it this way, if you have a hub already, there's more things you can control and you will use google home to augment the automation with voice control etc..
but if google home is all I have with some smart switch, lights and IR blaster, after a while the novelty wears off and I don't use it anymore cause it's tiresome..
Both scenarios are my experience.
Of course you can just make do with GH first but it might not work with the hub down road if you just get whatever smart switches/IR blasters/lights now. Some people choose a hub first and from there decide what works with said hub. Prices of a hub is not much more if you consider retrofitting the whole place.
It all depends on how much you need to automate.
I can honestly say after using google home for a while, it's more of a novelty and you might not use the voice command after.
Anyway what do you intend to get to integrate with google home? Sometimes a hub with compatible switch is cheaper in the long run than slowly buying more IOT things..
JJJ010101
Thanks for your comment..
Would you say that when the novelty wears off, you primarily use app control more than voice? I mean, even if the voice is not as useful, the app control is still much more practical?
Here's a non-exhaustive list of items I have in mind (either voice or app control):
1) TV
2) soundbar
3) Lightings, ceiling fan, aircon
4) Front door lock and door video bell
5) robot vacuum
SecretAgent
I still get Google home to turn on/off lights, fans, tv and aircon when I am too lazy to reach for the switch or remotes. It's up to personal habits.
pustefix
There are 2 levels of smart home that we are talking about:
1. Remote control, either you are using an app or using voice to control your devices, you are merely controlling them remotely. The novelty will wears off here but there are still instances where it is more convenient to either use app or voice to turn on/off devices.
2. Home automation, this is where things happen automatically, e.g. as you entered your house, lights/fans will be turned on, your favorite music will be playing, etc.This is where sensors come in and with sensors (either zigbee or zwave) you will need a hub to communicate with them.
Although most of you will stop at remote control, please give home automation some thoughts. After you get used to the automation, you will not want to go back.
Zerocool
1) TV
2) soundbar
5) robot vacuum
From a control perspective, I prefer app control than voice. Sometimes when TV is on, voice control is not so accurate as well. I'm used to clicking on my phone than talking to the devices. But that's just me.
viix
1) TV
2) soundbar
5) robot vacuum
No, I use automation. mostly sensors and some programming to determine activity.. so I dont even turn off the tv at night or leaving the home (using presence and vibration sensor on sofa plus a powerplug measuring power on my TV)
TV and soundbar quite straight forward. Either get same brand, or get a voice enable smart TV and sonos beam.
Lights still relatively ok. Depends on how much you want to spend. Ceiling fan, you stuck with PO Eco or ECO AirX with TUYA, AC depends if you getting smart AC or Normal AC and an IR Blaster/Smart thermostat like Ambi climate or sensibo or wyfy beam...
Front door lock and video door bell, not sure digital lock can be voiced unlocked anot.
Everything else is possible. But looking at these devices, not all brands can be intergrated into just any Hubs..
