Vulpix
Moderator
Moderator
No, I use automation. mostly sensors and some programming to determine activity.. so I dont even turn off the tv at night or leaving the home (using presence and vibration sensor on sofa plus a powerplug measuring power on my TV)
TV and soundbar quite straight forward. Either get same brand, or get a voice enable smart TV and sonos beam.
Lights still relatively ok. Depends on how much you want to spend. Ceiling fan, you stuck with PO Eco or ECO AirX with TUYA, AC depends if you getting smart AC or Normal AC and an IR Blaster/Smart thermostat like Ambi climate or sensibo or wyfy beam...
Front door lock and video door bell, not sure digital lock can be voiced unlocked anot.
Everything else is possible. But looking at these devices, not all brands can be intergrated into just any Hubs..
Installed my PO Eco fans into my new home recently. Absolutely love it, wind is good and it uses Smart Life so it was easy to setup.
viix
Nice, yes quite surprised the PO ECO fans have really strong wind flow. Went a few places to look and decided on them. Luckily when I got it that time they just started trialing the WIFI tuya module driver. And with the WYFY app developed by automate asia, it's also intergrated to my homey now!
viix
How much is the PO Eco fan? Quite many models
see qoo10 prices.. quite straight forward or you can go to their showroom warehouse around amk ave 5.
I like the fact that you buy the base model and you can swap blades. I bought too small blade and swap a for a larger one. self install when I changed the larger blades.
eudemon
Question for those using or used to having Wifi-only (no hub) smart devices setup, please share your experiences -
(1) Do devices work okay in a mesh Wifi system?
(2) Do devices work okay with a range extender/access point that use the same (or different) SSID?
Thanks!
viix
Thanks!
Base on my limited install at parent's place as not a full setup.
1) Occasional dropouts/device offline for those running 2.4ghz wifi. somehow the mesh network prioritise high traffic device and seem to drop devices if using 1 SSID. so u need to split 5ghz and 2.4ghz and it will improve.. if wifi is congested, need to plan AP near also just for the 2.4ghz wifi devices and USE ethernet backhaul. If you use wireless AP mesh not sure if it will be slow.
2) They need to be on same subnet. SSID different no issue as long as same network. If more than one subnet, they can't see each other.
seamonkee
Hi Folks..
My first foray into home automation and I truly need advice. So far I am using Yeelight E27 bulbs for my home (working well) and Broadlink to control my IR and RF devices like aircon, fans & TV.
My home is Google setup and we have Google Nest Hubs in our rooms.
Yesterday, I set up my Broadlink RM4 Pro to control my TV and aircon. Both TV and aircon setup well and can be controlled using Broadlink App.
However, when linking to Google Home, only the aircon appears and not the TV. So I can voice command to activate the aircon but not the TV.
How do I get the TV to work using Google voice command? Am I missing something?
Thanks so much!
blue_yoghurt
Hi Folks..
Thanks so much!
I have a similar setup with Broadlink as well. When setting it up on the app, it did mention that only the air conditioner will be exposed to the Google Home App. I have both Google Assistant and Alexa and it works fine on Alexa.
My workaround the issue is to have scenes created in the BroadLink/ihc app, then on Google Home, set up your own routines to run these scenes. It's a bit of hassle but it works for simple stuff like turning on/off your TV, switch channels and volume etc.
blue_yoghurt
Hi gurus,
I've got 3 questions on smart home hubs and will like to seek some of your opinions.
I've recently changed my lights switch to the Aqara light switches. (Thanks for the advice earlier!) I have a Xiaomi gateway and managed to find the Aqara light switches to set some automatic scenes on the mi home app.
However, the problem comes when i want to link it to use voice control through Google Assistant. Somehow the Aqara light switches are not exposed to Google Home through the Mi Home app. I've read somewhere that if i get the Aqara hub and using the Aqara app, it will be exposed to Google Assistant for voice control. However, I'm looking for alternatives solutions because i don't want to have too many different hubs in my house as i find it quite messy and confusing.
My questions are
1) Has anyone tried it with the Aqara hub? Will it expose the Aqara light switches to Google Assistant?
2) Is there any recommended home hub that is a bit more brand agnostic? This is so that when adding more smart devices from other brands in the future, I might not need to get another new hub for it as well.
3) I read on this thread about the Tuya Hub, will it be able to work to link the Aqara lights to Google Assistant? I've tried researching about it online but information on it seems a bit scarce.
Thanks gurus in advance!
Vulpix
Moderator
Moderator
I got a whole bunch of 1 gang Neo Coolcam Z-Wave light switches for sale, anybody want? :s13: Bought too many.
viix
Hi gurus,
My questions are
1) Cant help u here
2) Hubitat and Athom Homey are some.. but there are still some limitations to whats exposed.. You can workaround by creating virtual devices and then use the hubs to set the automation. IE my blinds are not exposed to alexa, but I use a bulb virtual device. By saying dim to X%, I can set the blind position by voice if needed.
3) Tuya is wifi and use their own API, Not possible for their hub to control aqara lights.
I know my homey can but again as I like to mention, if you get a more robust hub (like hubitat or homey) or even use Hassio, you will use voice less..
nemonic
Hi experts,
I’m thinking to replace my 4 gang switch to smart switch. I realised there are 2 types, with or without neutral line. Would like to know which should I get? I’m staying at HDB flat. When I open up my socket, I saw there are blue and red line. One blue line connect to a switch the rest are red. Seeing blue cable does it mean there is neutral? However looking at the connection it seems like all are live cable.
JJJ010101
Hi pros.. Anyone's using August smart lock for front door? Can I ask..what do you do with the metal gate door then? Still physical key?
drkcynic
Hi experts,
It seems without neutral is not stable. Always short circuit and stuff. You can read up more just google.
I went with neutral. I hired an electrician.
6 mths still all good.
Never regret even though it cost me around 1.5k for everything.
Vulpix
Moderator
Moderator
Agreed. Don't go with live-only ones. Went with neutral versions of the Z-Wave neo coolcam light switch, so far so good.
