SecretAgent
Anyone else having issue linking Mi Home service with Google Home App?
No problem.. with my yeelights and Google home.. but some appliances such as china Philips light bulbs from xiaomi (Mihome) doesn't work with gh due to restrictions..
BuaySaiHippo
Strange... Mine just doesn't show up on Google Home App.
My Mi Home App is set to Singapore region and my cameras are global version.
Do you have Mi Home showed under 'Linked Services' in your Google Home App settings as below?
mrwirus
Those using sonoff switches, which one should we buy? UK (square) or EU (round)? Seems like UK is cheaper but I'm not sure if it can be installed in SG.
mrwirus
Hi gurus.. I got a question that I've been trying to find out but I can't seem to find it.
I'm building a led light strip for my kitchen backsplash and the switch will be located inside the cabinet itself. Are there any led drivers or smart way to allow google home to switch on and off the led light strip together with the rest of the lights in the kitchen (going to be controlled by sonoff).
My led light strip point will not have neutral I think.
Thanks for the help!
viix
Put the same sonoff controller at the light strip switch area and you dont need a switch there.
Sure got neutral where the light strip is going so ask the electricial to route it to the switch area. Or just install the sonoff basic at the driver area.
Most controllers are for RGBCCT led like the gledopto I use. but they work on Zigbee with the Hue hub.
There are other WIFI controllers for basic 2 wire led strip but those do not integrate with ewelink app, and they are not designed for long runs or bright strips where you use alot of power.
coolnhappy
It seems without neutral is not stable. Always short circuit and stuff. You can read up more just google.
I went with neutral. I hired an electrician.
6 mths still all good.
Never regret even though it cost me around 1.5k for everything.
Why should not having neutral be unstable? It's just a relay or switch.
mrwirus
all these requires neutral right? I was thinking if I can don't tap on neutral for that one since it is just a 1 gang switch.
How to install sonoff basic? also requires a neutral?
I also see a lot on carousell selling those that are using the app magic home pro.. are those suitable for backsplash? Actually I don't think I need RGB for my kitchen backsplash I just want to be able to switch on and off via wifi/google.
thamsup
Hi Gurus! I'm new to home automation and I have a lot of questions. I am getting my BTO soon and I'm keen to integrate into my house. To begin with, may I ask for your opinions. Is it economically wise to add neutral line to begin with. Thanks senpai
viix
Yes, with neutral you have less issues in the long run.. especially when more smart devices comes out.. your infrastructure is ready..
mrwirus
Can I ask.. if I install a sonoff basic at the driver area. Can I still use the physical switch to on and off the lighting? Or no matter I on or off the switch it has no reactions?
Alphas
There are tons of led Controllers that integrate with Alexa and Google home. Those that uses magic home app has normal RGB, RGBCCT and even pixel led where each led can be individually addressed.
mrwirus
I kept trying to search for it but it seems to only have rgb wifi connections? Mine is going to be a single colour led lighting connected to a driver and wall switch..
And I see those wifi connectors seems to be different from the driver where u need live and neutral?
Alphas
If you are just running a single colour (eg warm white) led, then just get one colour controller. You still need a transformer or driver for the LED, there are basically either 12V or 5V.
I suggest getting the 12V Led strips as the brightness is more consistent due to smaller voltage drop. The current depends on the length of the strips.
Check my reno thread for more info.
https://forums.hardwarezone.com.sg/home-decor-furnishings-188/my-resale-hdb-4-room-renovation-modern-transitional-design-cozy-ambience-5875499.html
Here the url for many types of Wifi Led controller based on Magic home app, there is single color controller. It is the most versatile app for LED lighting.
https://www.aliexpress.com/item/10000190140860.html?
viix
My preference is 24v strips though. I do not need to run amplifiers for 10m runs at all. I'm using meanwell 24v drivers and 5in1 RGBCCT strips with gledopto controllers linked to the hue.
If you experience voltage drops, could be the strips or controller design..
Naqsaq
I'm just doing finishing touches on a DIY Apple HomeKit home automation system including Aircon, ceiling fan, TV, Preamp, sockets, IP Camera, etc. using a Raspberry Pi running Homebridge. Total budget seems to remain under $200 with all hardware included (nothing was originally HomeKit compatible). Would there be interest for me starting a thread to cover this process? Under what section in HWZ do you recommend me putting it to? I was surprised there was basically nothing about Homebridge here..
thamsup
Hi Gurus, can I check for laying neutral wire in my house. How is it normally be charged? Per electrical point or by number of rooms?
For example if I am planning to have 3 dumb ceiling lights connected to a smart switch. I have to pay for 4 points or just 1?
thamsup
Wow please share!!!
viix
Do share, I guess home bridge is not as popular as home assistant. And for most of us, the Wife acceptance factor is important lol.
I've tried Home assistant but the breaking changes are always a PITA for me. End up just using back off the shelf solution because of the time constraints.
