viix
Currently my BTO all the cables concealed in the wall. The electrician says if want to pull neutral for all my light switches it will cost a lot, as they need to hack a groove on the wall to conceal the neutral cables. Not as simple as taking out the trunking cover and adding neutral cables in.
Hence was thinking of no-neutral solutions and wondering if sonoff basic will work if I connect it at the light side.
Your electrician is noob. Mine is also concealed, and all my neutral is pulled. My electrician pulled 6 points with 6+6 live & neutral from 1 pt conceal conduit so can be done. He pulled a thick nylon cord with the original wire, then with the cord, pull 12 wires back to switch. I saw he applied some lube/soap on one end and another pulled from the other. Very fast. All done in a few hours. No hacking needed.
beyond_26
Which smart switch from tuya do you recommend? Looking for switch that need neutral. Rewiring my house.
if u want to use Google home, maybe the best switch is tuya smart life one.
It works without hub.
I just migrated from aqara cause only the eu hub and if u are on Eu server then Google home will work.
Neanderthals
most house no neutral.. never heard before spoil. last time only broadlink tc2 QC was bad.. and people connect light switch to ceiling fan.. sure spoil fast.
Care to elaborate more?
Anyone has experience with wiring ceiling fan and fan light to separate gangs on the same switch? I am thinking to wire it this way so that I can access the fan and light separately.
Most electricians should be able to do it without any problem right?
Also, can home assistant assign 2 different profiles (light and fan) for the same switch? My experience so far is on reading only. Haha.
bullfrog
If the switch powers the fan and light, then turning off the single switch will kill all power driving both the fan and light. Nothing HA can do to circumvent physics.
However, two physical smart switches on the same gang can be grouped as one virtually in HA so HA can manage the group, powering off/on both switches simultaneously or individually.
Alternately, if both can be managed by ir/rf, then you can leave the power switch always on and use broadlink to manage the fan and lights. HA can manage broadlink too.
Posted from PCWX using SM-G988B
zeroflame
Thinking to get a ikea motorised blind to replace my current one but seems like only can be controlled by their own remote. In the end bought a diy china generic dm25leu.
Motor rod installation quite straight forward. Ikea side bracket abit too big to insert into the rod cutting at the side. So need to modify abit the given bracket to secure them together.
Remote should be the typical RF433. Broadlink pro shld work just fine.
thekang
I'm new to automation. Just got the electrician to add neutral to light switches for HDB BTO.
Now that I'm ready to buy my Xiaomi Aqara light switches, my electrician told me I have 2x 2-gang-2-way switch in my living room (given by HDB).
Questions:
1) Aqara cannot handle 2-way switches right?
2) From my understanding, the correct way to install the smart switches is to convert back to 1-way, then program the dead switch to activate the 1-way switch to simulate the 2-way effect?
3) Is it difficult for electrician to convert it from 2-way to 1-way? What steps are required?
I will be testing the 2020 3-gang aqara, should be able to update here.
bullfrog
Questions:
Just have your electrician convert one of the two way switches to one way to manage that light. He will know how. The other switch, just remove it and use a cover plate.
Once you have a smart switch, you do not need two way switches anymore as you will eventually configure alexa or Google home to turn on/off the lights anyway.
Neanderthals
I see. Thanks! Can't wait to test it out when the reno is done.
WindBlade
Aeotec vs Fibaro vs MCOHome
Hi
I am fully renovating my place and was wondering what pros/cons are there to. be using relays like Aeotec/Fibaro/Shelly relay switches in the wall with traditional switch compared to during Smart Switches like MCOHome?
Anyone has any experience with any of them? Or have other switches to recommend?
Thanks
bullfrog
Hi
I am fully renovating my place and was wondering if I should be using Aeotec/Fibaro relay switches in the wall with traditional switch or should I be using MCOHome Digital Switches?
Thanks
If this helps, my configuration is aqara switches (with neutral) + xiaomi gateway +raspberry Pi withHome Assistant (hassio) + alexa
Instructions to perform tasks relay as such
Alexa - > home assistant - > xiaomi gateway - > aqara switch.
Home assistant has a mobile app so i can also use that if lazy to talk.
WindBlade
It can also greet me and say goodbye when I leave (done via samsung lock as it can tell which direction door is open to determine I'm ingressing or egressing.
Hey viix, wondering which samsung lock are you using? It has a ZWave controller that is able to communicate with your hub?
Also, any complains with your ZWave MCO Home switch? I am thinking of using that?
Were there any problems installing the switches too?
For yoru MCO Home switch, did you get all 4 Gang so u can use it to control scenes for the other unuse buttons as well?
Ya, quite redundant to have switches actually (smart or hardwired both) as I've motion sensored the whole place.
When I first started, all my switches were smart switch and dumb lights.
Then slowly philips hue/yeelight the whole places. What I did then was to remove my switch and terminate the light to always on. The switches with smartlight now don't connect to load (meaning no connection to light) and I use it to turn on scenes (to turn on a few lights configuration base on time of the day or the colour of the light based on time of the day.)
So why I say redundent is because with PIR sensor, I dont touch the switch anymore.. I have it just because the other members of my family prefer to physically use a switch to turn off although I always nag at them that it will auto off after a while when there is no movement..
So your MCOHome now all function as just smart buttons? How did You terminate the lights to always on?
What PIR Sensors are you using?
Vulpix
Moderator
Moderator
Questions:
Yeah just drop the 2 way switches. You will not need the 2 way nonsense once your smart home is setup.
lvlaTr1X
Interesting concept..
I am using ZWave MCO home switch, so far i got one of the 1 gang switch going a bit haywire, whereby the switch is on/off, the fan will remain turned on, need to tap the switch a few times before it will turn off the fan but that's after 2 years of usage already.
I think for your 2nd qns, he explained that he moved on to hue light, so hue light bulb will turn off upon sensor command.
WindBlade
Oh no. that doesnt sound good for a $170 switch.. hah.
So your whole house is using MCOHome switches? Do you regularly physically on/off those switches, or do you now use it mostly by voice and/or other automations. .asking cause I'm thinking if where I put the switches will be that important or not.
Can you also use other unused buttons in your MCOHome switch for scene controls etc? THat is your hub picks up the button is pressed and then activates some controls.
By sensor u mean PIR sensor will send a command to the hub that no motion is detected and the hub will switch off the Hue light?
WindBlade
Oh. Alexa can talk locally to Home Assistant without Alexa going to the cloud to voice decode and come back to home assistant?
bullfrog
No la. Alexa must have cloud. Without cloud, alexa doesn't work.
There are two ways to get home assistant to interface with alexa. The neater way is via the home assistant's nabu casa cloud. It's more device rich and very transparent. Any device HA sees, alexa sees. So if you rename a device in HA, alexa can discover the new name automatically. Add a device, it can be discovered.
The other way is to make every device in home assistant appear as Philips hue lights and have alexa discover them as lights.
I am using the nabu casa cloud.
viix
Hi
Thanks
You have no idea what's turned ON with toggle switches unless you are looking at the lights/load it's connected to.
IE, my master switch I've set at the main door is configured to represent each room on each gang, when I see the light on, I know something in that room is on (aircon/fan/light/sonos). Say if I leave the house, and something is on and I need it off, I just flick it if I want to, although my homey will auto shutdown everything once I leave my geofence. But my wife still prefers to physically touch a button so :s22:
Also, any complains with your ZWave MCO Home switch? I am thinking of using that? Were there any problems installing the switches too?
Using the DP728 or is it the 920.. sometime back so i forgot which model. it requires an add-on zwave module from Hanman. Hanman has 2 version of their zwave chip. One reports lock status and opening direction/type, another doesn't so make sure to get the correct one.
So far no issue with the MCO switches. The switch is deep so make sure you have sufficient depth. No issue for new development from my time onwards but for older houses, need to ensure. Installing wise is easy, just brief the electrician on how to install. My electrician damaged the face plate cause he thought need to use a screw to pry open but I got them to replace it. Just need to lift up and it will release.
Yes, mine is mostly 4 gang, only water heater is single gang with contactor in the false ceiling and my kid's room is 2 gang cause 1 for ceiling fan and another for light.
Terminating the lights to always on means I got my electrician to split the wire, 1 pair to load and 1 pair to switch.Because the switch is deep, I got the super slim wago connectors to split and got the electrician to do the termination.
Using Aqaras PIR & Contact sensors, neocoolcam contact sensors, philips hue and fibaro PIR sensors. mostly aqara cause cheap. Fibaro only cause I got them cheap from a corlick who bought too many. Neocoolcam was what I used first, but found them unreliable after the battery drained and replacing it somehow didn't work for the contact sensors.. their PIRs still ok and I prefer them as they respond faster, so they are in use where I need faster response.
Check with automate asia, your's was probably an old batch with relay problems. They will replace it. Mine was new batch so no issue with it 3 yrs now. There was a batch the magnet was stuck to on so MCO replaced it.
Yes, since my whole place is on Phillips hue, so I let the hue hub manage the light and homey manage other things and some transitions. I find it faster as homey managing 40 bulbs can get slow especially when I set bulbs to slowly fade up over a few seconds and change color temperature over the course of the day. So homey will only manage scenes, ie disable hue sensors when my roborock is vacuuming when the house is unoccupied (else lights will on when the vacuum is roaming) set lights to full white and 100% when I set homey to arm for security when sensor tripped when no one is at home, and other stuff like dimming lights for netflix etc)
lvlaTr1X
After checking with the supplier, seems like the relay got magnetized and stuck at the "On" position, taught me to turn off the breaker and give it a few knock to release it.
I don't use the physical buttons much because I am lazy, so its Alexa mainly for me but when visitor comes, they still need a physical switch for toilet light or kitchen light. Voice is also hard to be used when the house is filled with visitor as the conversation noise would drown your command voice.
I used one of the unused button to link it to my kitchen light, so if i already walked away from my kitchen, I can still turn off the kitchen light from the living room light switch. Not sure about other hub but I am using Fibaro, so that's possible for the unused switch to be used for scene activation.
