Me. Paired with Xiaomi gateway v3.
No issues. Works very well with homekit
anyone tried the 2020 model 3 button aqara wall switches?
is the supposed issue with no neutral switches legit or just a scare by competing firms in the smart switch space?
a lot of china sellers sell the neutral switch + capacitor as no neutral needed switchesis the supposed issue with no neutral switches legit or just a scare by competing firms in the smart switch space?
I will be getting the keys to my two bedroom private condo unit soon and would like to get started in smart lighting. The exact lighting plan isn't up yet, but so far the plan to get is to get some Google Nest device (Either the WiFi or Mini with a separate router), along with a Zigbee/Z-wave hub and use a smart switch/dumb lights system if possible.
1. Are there dumb lights that are dimmable and can change from warm to cool white? Or do I have to go the smart bulbs route for this?
2. Are there any contractors out there that you recommend that can do the wiring for such a system?
Please excuse if the above questions are totally off/ beginner. Thanks in advance for the help!
Nice, using china server right? Do you use mi home app?
If chiu know circuitry and understand how non neutral switches tap power from lights and other devices, chiu will know it's not a viable long term solution...
Question ish how long your lights, fans, other appliances will last with the non neutral switch tapping power through all this connected devices to keep it powered....
Once chiu understand this, chiu will understand the lights flickering issue on lights with non neutral switches and other non compatiblity issues... And why these connected devices to non neutrals will chiu and die out or spoil much faster than you can imagine...![]()
buy cheap, buy twice lor
my house need to do external trunking to pull neutral wire.. too many lights and too ugly. bo bian need to consider non neutral. can share what you used that sucks?Moi used non neutral switch before, install riao lights flicker, neh mind, install capacitor, still flicker, nvm take out revert back to normal switch... Knn nao moi led light driver rike sot sot already...![]()
i know the problems with non neutral but bo bian can only switch to neutral the next big renovation.Tried many brands and oem, still same problem de...
Non neutrals use a special timing circuit in the pcb to alternate live and neutral current through the original live in and out into the non neutral switch to power it...
Nao chiu know why the lights flicker with a non neutral switch and need capacitor....![]()
Things also spoil faster, as residual current ish always running though the same wiring through the connect lights or device...
did you have to use capacitor? is it possible that the capacitor was installed at the wrong place that cause the problems?Non neutral switches do not cut off the electricity completely. They simply keep the current so low that the lights won't switch on. That's why they have a minimum wattage on lights. For xiaomi, typically is >4 Watts.
The quality of the lights also matter. If the led driver is of poor quality, the lights will flicker.
I'm using Phillips led lights and have no problems with flickering. Even those very low wattage 2W philips led will not flicker.
