lvlaTr1X
Check with automate asia, your's was probably an old batch with relay problems. They will replace it. Mine was new batch so no issue with it 3 yrs now. There was a batch the magnet was stuck to on so MCO replaced it.
Thanks, checked with them and gotten a concept on how to clear the magnetization.
Vulpix
Moderator
Moderator
Oh no. that doesnt sound good for a $170 switch.. hah.
So your whole house is using MCOHome switches? Do you regularly physically on/off those switches, or do you now use it mostly by voice and/or other automations. .asking cause I'm thinking if where I put the switches will be that important or not.
Can you also use other unused buttons in your MCOHome switch for scene controls etc? THat is your hub picks up the button is pressed and then activates some controls.
By sensor u mean PIR sensor will send a command to the hub that no motion is detected and the hub will switch off the Hue light?
If you want something cheaper can consider the Neo Coolcam Z-wave switches? Get MCO if you need a 4 gang, that's what I did. My 2 gang and 1 gang all Neo Coolcam while my 4 gang is MCOHome as it's the only brand with it. The price of one MCO 1 gang you can buy around 2-3 of the Neo Coolcam, spoil just buy new one.
yamashita
Moderator
Moderator
Neo coolcam is a good buy - still working fine for me since the last time we discussed. :)
Vulpix
Moderator
Moderator
Just a shame they have max 3 gang. Their 3 gang layout also damn weird all the buttons super close to each other. :s22: My 4 gang is from MCOHome since it was my only choice.
viix
How’s the recent hubitat update? Read some issues people are having.. might be looking at getting a c7 for my parents place.. can it be remotely managed?
Vulpix
Moderator
Moderator
It's the usual pains of a completely brand new hardware revision. The old C5 initial launch also had some hiccups, but it gets resolved very quickly. C7 using hardware that no other brand is using including new radio, so there are some hiccups. Hubitat can't be remotely managed, might have to create a tunnel and manage if have to. My C5 is completely stable right now, never crashed since February after setting up. Only restart to update firmware.
WindBlade
Yes, mine is mostly 4 gang, only water heater is single gang with contactor in the false ceiling and my kid's room is 2 gang cause 1 for ceiling fan and another for light.
Any reason why you choose Contactor vs other methods such as Tuya high ampre switch or Aeotec Heavy duty Relay?
Using Aqaras PIR & Contact sensors, neocoolcam contact sensors, philips hue and fibaro PIR sensors. mostly aqara cause cheap. Fibaro only cause I got them cheap from a corlick who bought too many.
Is Fibaro/ Philips hue expensive sensors any better? or you feel no diff from standard Aqaras?
Yes, since my whole place is on Phillips hue, so I let the hue hub manage the light and homey manage other things and some transitions. I find it faster as homey managing 40 bulbs can get slow especially when I set bulbs to slowly fade up over a few seconds and change color temperature over the course of the day. So homey will only manage scenes, ie disable hue sensors when my roborock is vacuuming when the house is unoccupied (else lights will on when the vacuum is roaming) set lights to full white and 100% when I set homey to arm for security when sensor tripped when no one is at home, and other stuff like dimming lights for netflix etc)
When you use voice commands, there will definately be lag right? Since it has to go to the cloud and decode before sending commands to your hub.
When you say "I let the hue hub manage the light", that only means on and off?
I saw you were using Gledopto light strips as opposed to real Hue ones. Any feedback on those so far? For Hue lights, you using real Philipps ones?
Cause I am considering Lifx bulbs as the reviewers for those bulbs seems to be super good.
Similar for Lifx Light strips.
WindBlade
So I guess you prefer the MCOHome one a lot more than the Neo Coolcam ones?
WindBlade
greenbubble
Actually automation is still quite limited. A lot of household work still need man to do such as cleaning.
viix
Only reason is because when I was installing contactor, the high amperage switches were not common then,
and because my heater is in the false ceiling that's not so accessible, I don't need to worry about zwave reception inside or having to go in to set the device to pairing if I needed to. I manage it from the switch at switch level height vs climbing up to the ceiling to troubleshoot.. Not that its common, but I think a dumb contactor has less issues than a smart switch in the long run.
In terms of sensors, it's more the protocol than pricing that should be considered.
Zwave sensors are more responsive than zigbee (fibaro/neo vs hue/aqara). I get 1/4s response from zwave vs just under 1 second from zigbee (although hue sensors to hue hub is as fast as zwave on my homey)
The only plus for the more expensive sensors would be
1. the tamper alarms (which I dont use and dont find it useful) on fibaro
2. HUE sensors report luminance all the time vs aqara motion sensors report lux only if there is motion detected.
But that is negated with their new luminance sensor that reports every few min.
No, my hue hub manages all the scenes for each room (the hue sensors can set scenes based on time of day and weekend/weekday + transitions (dim from off to bright over 10sec and hue labs mimic morning sun so the lights turn on slowly and brightens over the morning for more natural wake sequence). I like hue cause I can set lights themes in rooms and over a group of lights and the whole house more easily. It takes alot more time to do that with homey or any hub vs the using the hue bridge. But only useful if your whole place is hue.
I mostly use Philips Hue. the gledopto ones are for those extras, under the bed, behind my kitchen shelves etc.. I have like only 5-6 gledopto now. I had gu10 gledopto but found them having poor connectivity when using it in the balcony so swap to philips one. think the metal track light casing blocking the lousy antenna in gledopto even though I have 8 bulbs at 50cm interval from each other. I dont have issue with philips. Downlights I'm using Zemismart hue compatibles only cause hue doesn't have them them in RGBCCT, they only had white ambiance that time.. But I'm waiting for the zemismart to spoil so I can replace the new Hue one that just launch this year in UK. One reason I prefer hue over 3rd party is how dim they can go. At 1% brightness, its very good for maintaining night vision so I have a night light scene when I wake to change my baby's diaper and night feed. Dim enough that nobody gets woken yet functional for task. Gledopto and Zemismart is damn still bright at 1% and colors is still alittle off. (3200k is not accurate and RGB still abit off) Only think I like about gledopto/zemismart is that their RGB is more saturated than Hue as hue tends to add some white from the CCT White leds on to RGB colors to give a brighter effect wheras 3rd party lights is only using their RGB leds.
Lifx is ok, but value wise in terms of functionality, hue wins. simply cause hue app is always updated, hue bridge adds alot of function and zigbee vs wifi means you dont burden wifi with polling traffic between the bulbs.. Plus hue has alot more intergrations than lifx. I use hue a lot for entertaining. Hue sync for movies, hue disco for some weekend play for my children (esp with CCB) and the colour themes are popular for those holiday parties with kids and friends.
Eating also. Else man will feel incapable. But automation frees up time to do more things, I've kinda like how I can bring my fussy kid home and go straight to shower and bed without fussing for switches and looking for remotes when it's past bedtime.
Did you all choose the MCOHome ZWave or Wifi version ah? And whats the reason ah?
Zwave, wifi has a lower number of device limits although modern routers can handle it. Zwave has longer range. 1 example I experience was putting a rain sensor in the balcony under a metal hand rail. Wifi sensor had problems with connectivity but no problems when I swap it out to zwave. Some people also experience wifi outage when installing switches in metal recessed brackets if their AP is not nearby.
BlackLab
No la. Alexa must have cloud. Without cloud, alexa doesn't work.
There are two ways to get home assistant to interface with alexa. The neater way is via the home assistant's nabu casa cloud. It's more device rich and very transparent. Any device HA sees, alexa sees. So if you rename a device in HA, alexa can discover the new name automatically. Add a device, it can be discovered.
The other way is to make every device in home assistant appear as Philips hue lights and have alexa discover them as lights.
I am using the nabu casa cloud.
Posted from PCWX using SM-G988B
Just to add on to this, Nabu Casa is probably the best way to integrate Alexa voice control with Home Assistant, as it does most of the hard work setting up and maintaining functionality, but it costs US$5 a month to use.
Emulated Hue is still quite simple to setup and doesn't cost anything. It is less robust, but if you just wanna do simple on/off commands, it works great.
Note that it seems to only work on port 80, so if you're using that for something else and cannot change, this might not be an option.
There is actually a third way - using Home Assistant's Alexa Smart Home Skill.
It's offers the best of both worlds (free and robust device support), but requires quite a bit of setup, so not recommended if you're not comfortable messing around with Amazon's deveoper tools.
WindBlade
Haha i thought bright and saturation is good :)
What about the gledopto lightstrips then? I think that would be much better cause
1. Has more lumens, Hue only supports 1600 lum max..
2. Has RGB + CCT which Hue is lacking?
lvlaTr1X
I use HA-Bridge to emulate hue control and Alexa will search the device as a hue bulb, when activated it will do a call to Fibaro API.
Alexa -> Ha-Bridge -> Fibaro API
Using this method, voice command takes about 1/2 sec to turn on the light as compared to native fibaro alexa skill which takes up to 5 - 10 sec to turn on the light.
BlackLab
Can't comment much on the Fibaro service, as the topic was originally about integrating Alexa voice control with Home Assistant only, of which there are the 3 available methods, to my knowledge.
But yeah, 5-10 seconds does sound too long for it to be of practical use. I'm not sure the person who originally asked about Alexa integration is even using Fibaro devices though.
In any case, I believe the one you're using is akin to the second method I mentioned, Emulated Hue, so my point about its pros and cons is still valid.
WindBlade
Can you elaborate more on this method and how it works?
Hmm.. Is this Alexa voice command?
If it fully local or is it cloud based?
By Fibaro API you are saying with Fibaro Hub?
viix
Bright and sat good for place you want to paint with colors, but for night I prefer hue. As you can create a more cosy atmosphere at home with little pockets of light and dark areas macham retail/f&B lighting, vs 一盏灯 one splash of bright light.
2, i refering to their Garnea/Aphelion downlight which is only white. But 3rd party their CCT is off when adjusting with the hue app. Except for light strips where you can get your own high CRI CCT strips, hue one is actually quite good for the price.
plustwo
anyone diy bluetooth beacon with esp32? which board to buy? seems like many different model
