Elon Jobs
Cool find: Signature Smart WiFi Switch - 20A - Smart Home Automation for S$45 https://carousell.app.link/b9vC8VdKD9
You can try this. I’m using the old 20A eTouch from the same seller for 2.5 years but it is no longer in production.
Hi Guys,
Can recommend me a smart switch for Heater (20A). (Sick and tired of forgetting to switch it off)
Best if can provide link to taobao product page.
zeroflame
is there a door sensor device which can notify me if the door is open for like x minutes?
Can work without a hub/gateway
my mom keeps forgetting to close the fridge door properly.
Greenie6970
You can consider the RAPLINK wifi door sensor, no need a hub.
You can automate via the App that when the door is opened for 5min, send a notification to your hp.
If you are more adventurer install a siren so that it gives alarm when the door open more than 5 min. Haha....
Baroness
Hi, I have a couple of blinds that's powered by somfy RTS motors. How do I know if they can be controlled via automation and if so what kind of frequency or hub works with it? Also the blinds are in different rooms, do I need like a hub in each room?
Posted from PCWX using Redmi K30 Pro Zoom Edition
bullfrog
My approach in discovering for a dooya blind was to just buy a secondhand broadlink rm pro from carousell and try. Can find them going for 25-30 bucks on average. If broadlink doesn't work, most likely you will need a proprietary somfy controller.
Posted from PCWX using SM-G988B
applegal88
Hi all,
I’m gonna renovate my bto soon, and am thinking of getting some smart home gadgets.
I’m looking at smart curtain, smart blinds. And smart switches.
1) smart blinds:
-anyone using IKEA smart blinds? Are they good? Saw this online but have yet to go to ikea Alexandra to check it out.
2) smart curtains:
- anyone using xiaomi smart curtains? Are they noisy? And where do you buy from? Do they work directly in SG if I were to buy from taobao?
3) smart switches:
- I realised that smart switches seems to have relatively short lifespan.
What Brand do you recommend, and how Long have you been using it?
(Initially wanted to get no neutral ones, but seems like they are quite unstable, thus, am considering those that requires neutral).
TIA!
Baroness
So I went ahead and got a broadlink rm pro as suggested. Didn't work with somfy but worked with my outdoor blinds of unknown motor type ☺️ however I can't seem to get Google to activate it? It's linked to Google home but when I gave the common it says not activated?
Baroness
Hi all,
I*********m gonna renovate my bto soon, and am thinking of getting some smart home gadgets.
I*********m looking at smart curtain, smart blinds. And smart switches.
1) smart blinds:
2) smart curtains:
3) smart switches:
TIA!
I fitted my entire house with aqara smart switch with neutral. They work as a normal switch but can be pai ed to xiaomi gateway for automations. Coming 2 years no issue at all
SecretAgent
Configure it as a dumb generic light switch under that ihc app, don't set it as a "curtain". Google should be able to just recognize it as a dump light appliances which does only on and off.
Baroness
I see. Shall give it a try tmr, thanks!
bullfrog
Too bad about your somfy, but you're almost there for the other blind! Not sure about Google home as i use alexa. However to get it to work for that, i used the ihc app (not the newer broadlink) and after clicking the broadlink device in the app, i added an appliance, selected lamp (lamp is more compatible) then selected "cannot find my brand" and to learn from remote.
Program the blinds to open or close using the on and off buttons for the lamp. On to close and off to open.
It appeared in alexa after linking. Might be the same process for Google home.
SecretAgent
Exactly same for Google home.. practically any remote signal the broadlink can capture it can be programmed
bullfrog
Just to add, outdoor blinds are fun to automate. You can link broadlink to IFTTT and configure your blinds to close when it starts to rain. I'm using Wunderground on IFTTT for weather updates.
viix
I find wunderground weather not as accurate for singapore. I get notification of inclement weather even on sunny days.
bullfrog
Well ya. The best is to have a leak sensor on the roof powered by solar. However that requires spending more money. This is free and works more often than not.
IceX
I’ve just ordered this.
A few questions
1. It can work with the Mitsubishi aircon, Samsung tv and fanco ceiling fan in my living room?
2. All I need is google mini if I want to use voice commands?
3. What about the other aircon units in my other rooms ?
4. Does it work with robot vacuum?im using roborock.
viix
Well there's the govtech weather api.. which I'm using.
ErinaMizuno
Anyone bought any alexa compatible fridge? Cant seem to find any in sg. LG have but i dont think it is for sg market
BlackLab
A few questions
Most of those appliances you mentioned probably use IR, which is line-of-sight, so yes, the RM4 Pro will work with it, but 1 room per device.
So 1) You put it in your living room where it is aimed at your Mitsubishi aircon, it will work.
Samsung TV - probably, if the remote uses IR and not RF. Fanco ceiling fan is probably RF too. Thing with RF is there's no guarantee it'll work, especially if the appliance uses rolling (encrypted) RF codes.
2) I don't use Google Assistant, but I think so.
3) A single device won't work on the other air-con units. Just imagine the signal is like you're pressing your remote controller from your living room, unlikely it'll reach the other rooms.
Even if it does, that means your one RM4 Pro is controlling multiple units at once, which I doubt is what you want. Cause that means you send an "aircon ON" command, all air-con in range will turn on instead.
4) Again, probably yes, but you need to position the RM4 in a spot where it can still send signals to both your air-con and your vacuum. (I'm assuming your Roborock is in the living room too.)
