plustwo
- Dec 28, 2009
seeing this makes me more confident of ordering some non neutral switches to try out. never thought it might be the quality of the driver. but if the driver keeps building latent charge but not releasing it, it will degrade faster right?No additional capacitor installed. I only replaced the switches.
The problem with poor quality led drivers is that the voltage regulator is not robust enough.
Good quality drivers will either output the rated voltage or zero. For example, if the rated voltage is 24VDC and the driver does not receive enough power, the driver output will be 0V thus no power to the LED at all.
The cheaper drivers will continue to give out fluctuating low voltages like 2~10VDC or so because the non neutral switch need to keep circuit alive to power itself.
This fluctuating low voltage is causing the led to turn on and off thus causing flickering.
which switch model did you use? i'm looking for something that looks similar to the click switches everyone is familiar with. seems like many china models all turn into the glass press type.
