Alphas
I did not encountered any issue with China power plugs for my wemax projector and Viomi instant water dispenser. In fact I cut the wires and replaced it with UK power plug.
baineteo
China plug themselves (if coming from reputable manufacturers) are no issue. The issue is with universal adapters. You can use them but be sure to use good quality ones. If the fit is loose you risk the pins arcing, resulting in overheating. The other thing no one mentioned is because they don’t have safety mark I believe they won’t be covered by fire insurance (should anything happen, that is).
My smart home blog:
http://www.housetosmart.com
koolkool
yes installing it will remove the issue faced with non-neutral.
nope, i ran zero neutral on my end.
i install it myself.
Hi. Thanks for the reply. Can I check what is the brand you used for your smart switches and if you recommend this.
Sent from Xiaomi REDMI NOTE 9 PRO using GAGT
koolkool
Anyone has installed zemismart curtains? There is the ZigBee and WiFi version. ZigBee need hub so I should go for WiFi version? What are the major pros and cons of using WiFi version? The tracks seemed to be adjustable so I should just select the closest fit? I'm thinking it buying from taobao and get someone to install. Anyone can recommend handyman who is reliable to just installing the tracks?
Alphas
My smart home blog:
Especially appliances with high power draw > 1000W, adding adapter overheats the plug due to increase in internal resistance. Just cut the wires and replace with UK plug directly, done in 5 min rather than using an adapter.
Backto
Thanks both! :)
tweety_piyo
anyone using non-neutral aqara switch wired to a ceiling fan experience random fan turn off ? the fan lights still work but the fan will randomly turn off. need to on/off the main switch again to get it working again
jikilan
I am using zigbee version for my whole house. Never go for wifi version. If wifi signal weak in some areas then you are gg.
Be careful and check your motor. They might send you wrongly. My case, one of the motor they sent was me a wifi curtain, follow by a ZigBee blinds curtain. And third time the correct ZigBee is on its way to sg.that seller is quite responsible and live to the brand.the motors all looks the same. The pros for ordering from china was cheaper than local famous brand by 3-5x and quieter too. The only cons other than smartlife itself is the curtain track. It break down into smaller tracks. (Unlike local, one long track) When u put the curtain at very high position, u will hear the dragging sound, the curtain hook/hanger hit the track a bit not so smooth. So need to put lower. But if u hide the curtain track with a false ceiling. This is not a problem at all. Pm me for the handyman contact. A friendly old coupon that is very helpful in helping me setting up my 4R HDB windows. Price is reasonable too.
Let me know if you want curtain guy contact too. Mine introduced by that handy man.
cueball1981
Do let me know if this post is not suitable. I will remove it. I'm selling unique DIY possible smart curtain. That is retractable, etc between 1 meter to 3meter. There is a special slider mechanisms. Wifi connect via Tuya or smart life. This version is ideal for DIY job.
eudemon
Anyone else use Sonoff T-series wall switches and encountered the following issues before? Mine worked well for a year till recently. Can't reconnect to wifi (intermittent or no wifi light) and even the physical switch buttons (which don't need wifi) don't work.
s_m_hafeez@hotmail.com
Hi all,
Have some questions regarding Mi Home and Aqara compatibility.
Background:
My home is setup with xiaomi hub with all aqara sensors (contact, motion, temperature) and switches and lights from yeelights. All this while, I was using it in Mainland Chinese server for xiaomi and yeelights. I set the power switch to wireless mode to toggle the yeelights and use voice assistant via alexa with openhab integration.
I noticed recently the singapore server supports the wall switches. I ordered the mi hub but it says it is not compatible with wall switches and the app said it is compatible with the aqara hub only. On buying the aqara hub (m2) with singapore server, it is not detectable in mi home. But can detect in aqara app and all my sensors and switches can be paired except the yeelights.
Good thing is I am able to control the wall switches in non Chinese server and via alexa direct integration. Bad thing is I am not able to control the yeelights.
Now I am thinking to change the hub to aqara m1 with singapore server supports.
Question:
And I have the following questions,
1. Can the aqara m1 hub be setup with mi home (sg server) and aqara app (other region) at the same time.
2. I moved the yeelights to sg server, if the aqara m1 hub is detectable in mi home sg server, can it be set in wireless mode to control or toggle the yeelights in wireless mode.
Sorry about the long post and I would really appreciate if someone can share their experience or expertise on it?
Elon Jobs
Hi all,
Background:
Question:
koolkool
Hi Jikilan, thanks for your advice. Will get ZigBee version on your advice. I have PM you about the contact.
Do you guys also setup Home Assistant to integrate everything centrally eventually? I am not a Linux expert so this setup maybe not going to be a walk on the park for me. I see most smart stuff like switches, curtains have their own app to do some control and scheule, just that if I need to use different sensors and conditions to determine a specific action, seemed like only Home Assistant is the setup to have.
I was also reading about Google nest home. Do you guys also have them? Where do you place them? One in living room, one in kitchen and then there are the bed rooms? Can I do voice control in my bedroom if I place it at living room? Wondering if I should buy so many of them just to do voice commands in the house.
Sent from Xiaomi MI PAD 4 using GAGT
Melsolut
Hi,
Am new to this. I have heard accounts of home automation failing to work when there was a M1 fiber breakdown (basically no internet access) back in Dec. Is there a fallback to use the home's internal network?
batniss
Hi,
if yours got IR - i.e. like mine - broadlink gateway brain
u can always fall back.
Elon Jobs
Paul Botak just mentioned this new hub which works when his WiFi is down.
Hi,
pustefix
In order to communicate with devices from different brand, you need a software/hub that can do that, e.g. Home Assistant, OpenHAB, Hubitat, Homey, etc. Please check the compatibility list before deciding which one to go for.
For Google Home, ideally you need one in each room that you want to use voice command. You don't want to shout in one room in order for it to listen in the other room. Start with one first and expand as need arises.
jikilan
+1 on google home part. You can install those with screen in bedrooms as control panel. Then the rest of the rooms just smart speaker will do. I have installed in all the rooms except bomb shelter (yes, including toilets). So make sure you have enough power points. Like pustefix said, once you understand the room concept then very easy to control. You can think it like a logical grouping of your devices. Eg: when you said "turn on the fan", how google know which fan? What if your living room have 2 nest mini and 2 fans? Hehe...
weeguy
Question for the experts here. I'm currently using a Mi Control Hub (SG version), and using a Wireless Switch button as a doorbell. However, given the distance between the two, the button will sometimes lose connection and fail to trigger the notification when the doorbell button is pressed.
is there any way to extend the range or insert a relay between the two? Bringing them closer is not an option, since the Control Hub also needs to be within range of another set of buttons that control the lights in the bedrooms.
Link to the devices I'm using: https://passionhome.sg/product/xiaomi-mi-smart-sensor-set-singapore-version/
