landslot
Hi Guys,
Am looking to get my new Condo in about 6 months time and now looking to built a smart home with Apple HomeKit.
Base on my understanding of Smart Wall Switch, a neutral line is needed to ensure that status of the switch is shown even I am outside. But does adding a capacitor solve the issue or the capacitor is more towards the flickering of the lights. Or the only way is get someone to wired all my smart wall switch with neutral. As the wiring are already done for a new condo, was hoping not to undertake a major renovation on that.
At the same which Wall switch would you recommend? I do know that Aqara does support HomeKit. I am also building onto homebridge for HomeKit for stuffs that does not have direct HomeKit support. So far I have tested a few non brand tuya power socket and power strips. All are working fine with homebridge with HomeKit
would like to know also does anyone use the Aqara D100 Door lock?
RyanJ
If there is going to be a major renovation exercise, get the electrician to pull the neutral wire down to switch level, so as to provide power to the light switch even when light switches are off. the capacitor is for anti flickering.
For folks with no neutral wire to switch , Lutron has a product endorsed by Hue
But that is if your light is Philips Hue.
https://www.lutron.com/en-US/produc...immers-switches/smartbulbdimmer/overview.aspx
RyanJ
I was also reading about Google nest home. Do you guys also have them? Where do you place them? One in living room, one in kitchen and then there are the bed rooms? Can I do voice control in my bedroom if I place it at living room? Wondering if I should buy so many of them just to do voice commands in the house.
I have one in almost every room ( 2 are google nest hub ) , 2 in living room and 2 in kitchen as pairs.
u can do voice control in bedroom if u shout loud enough for the device in living room to hear ..
simwb90
Hi all,
I am planning to use Shelly 1 or Shelly 1PM to convert my dumb switches to smart switches.
My ID told me he wouldn't be able to fit it into the switch casing though as the wires would take up all the space.
I've told him to run neutral throughout the house in anticipation for this.
1. Anyone has such an experience where Shelly cannot fit into the switch casing? Any proposed alternatives?
2. Where do you get your Shellys?
landslot
Thanks for the confirmation as we are not going for any major renovation for a new condo guess we will try to look at the rely of sonoff ZBmini or sonoff mini R2 as a work around.
Hi all,
I am looking at sonoff ZB or the R2 as I am unlikely to do any major renovation for a new house. As I will be getting the house in another 6 months time. I guess I can order a set or two to test it out.
Hyphos
Hi, any recommendations for motorized blinds? Looking for those that can keep rain/bugs out and retain aircon. Best if got rain sensor.
neemod
Non neutral? Your relay has magnetised and is stuck in the position until the power is cut off. you can try removing and giving it a good shake but likely will reoccur. The magnetisation happens when the load is too high or there was lightly a large surge current causing it to magnetised.
It's the same daily business for my broadlink TC2. I'm getting sianz of these switches... whether 1-gang or 3-gang, all kena. Capacitor fixed, also same. Sometimes long or doublepress also no response, take out cover, do the same on the inside, also no response. Off circuit breaker and on again, can't solve. In my house im the smart one so i use broadlink apps to toggle the switches, surprisingly apps can turn off; but the not so smart ones in my house more used to manual press, and it doesn't work; now i'm under pressure to revert all back to the normal switches. My 3-gang had this problem since day 1 i installed, i feedbacked to seller and she asked me to add capacitor, take video still got problem, accept 1-1 exchange, exchange liao new one also same; i then start to think something wrong with my house's electricity? Then i just bite the bullet since it's just 1 switch, thinking maybe after a few reset it'll be ok. But things just get bad to worse, more switches got frozen. I'm changing house soon, thinking of getting another type but then read this bad news from aqara... sianz man. What do you recommend?
Just opened up 1 spare TC2 and check, non neutral; thing is for non neutral i only heard of flickering issue during off state problem, no discussion or video on the problem im having until you guys bring up Aqara; i was very hopeful of Aqara actually, since it's known to work without wifi that kind of thing; now really lost again.. what should i get sia??
Alphas
Relay got stuck is a fault on the electromagnet. The only way is to replace the relay with another brand.
charsiewfan
I am using zigbee version for my whole house. Never go for wifi version. If wifi signal weak in some areas then you are gg.
Be careful and check your motor. They might send you wrongly. My case, one of the motor they sent was me a wifi curtain, follow by a ZigBee blinds curtain. And third time the correct ZigBee is on its way to sg.that seller is quite responsible and live to the brand.the motors all looks the same. The pros for ordering from china was cheaper than local famous brand by 3-5x and quieter too. The only cons other than smartlife itself is the curtain track. It break down into smaller tracks. (Unlike local, one long track) When u put the curtain at very high position, u will hear the dragging sound, the curtain hook/hanger hit the track a bit not so smooth. So need to put lower. But if u hide the curtain track with a false ceiling. This is not a problem at all. Pm me for the handyman contact. A friendly old coupon that is very helpful in helping me setting up my 4R HDB windows. Price is reasonable too.
Let me know if you want curtain guy contact too. Mine introduced by that handy man.
Can share the cost to install smart curtain for the entire house? TIA
Perdedor
Read that it would be more ideal to pull neutral wire to every smart switch for new BTO because it prevents low amperage from 'activating' the lights and can help prolong the lights' lifespan..
Anyone had done so and don't mind sharing the cost of having an electrician to pull neutral wires?
Cryptrus
Anybody having issues linking Google Home to Smartthings. Mine suddenly unable to work. So i unlink Smartthings to Google Home and then relink. End up, i got error message saying that " Setting cannot be updated, check your connection". Found in Google Linked app listing that Smartthings is there and also under Smartthings linked list showing google home. But my Google Home app dun have smartthings linked and not showing all the devices in Smartthings. Also command via Google Home cannot activate Smartthings devices.
Anybody can help? Saw this issues months n years back after searching in google but the solutions given not working.
TIA
stam
Anyone using Google Nest? why is it the country can only select China/Russia under Asia?
koolkool
Hi. I asked electrician recommended by ID to look at running neutral wire. He mentioned I need to get the smart switches. Can I confirm once neutral wire has been run, have to install the smart switch immediately (cannot use back the original non smart switch as a temporary switch)? This pose a problem if cannot leave the wire there while I source for the smart switches. I am thinking of sourcing the smart switches from online purchase rather than get from the electrician. TIA for replies.
Perdedor
Mind sharing the switches you'll be getting? And also, the cost of pulling the neutral wire for your whole flat (I presume a BTO)?
homeautonoob
I just got a unit from Hubitat to auotomate my smart devices and it's working well with my zigbee devices. My friends are keen to order for their own home, anybody interested to jump in together to share the shipping cost?
Does anybody else use Hubitat in Singapore, can share their experience?
currypox
Hi, can ask if anyone know why my Aqara wireless rocket switch don’t appear in google home? It’s already appeared in Aqara app. And I linked google home to Aqara app, but only sensor appeared in google home
dereklim1985
I now thinking about my new house coming soon, so I decided to change all lights, blinds and electronics to integrate with Google home app, what is the best brand or model that I should use? like example my light switch, the power plug and curtain drawer.....
koolkool
[ICODE][/ICODE]Mind sharing the switches you'll be getting? And also, the cost of pulling the neutral wire for your whole flat (I presume a BTO)?
Hi. I got quoted $31 per point. Asked for 13 points for neutral wiring.
For the smart switches, still searching for a suitable one. Looking at zigbee and with capacitive touch ones. I understand WiFi ones will be a problem if there are weak WiFi signal and there are limits to number of devices connected to wifi. I'm currently shortlisting this from Aliexpress
AVATTO
https://a.aliexpress.com/_msG7NkBMy ID not too familiar with smart home, so looks like I need to do this as a more middle term project. Don't think can finish all these by the time I move in to new place.
