Perdedor
Hi. I got quoted $31 per point. Asked for 13 points for neutral wiring.
For the smart switches, still searching for a suitable one. Looking at zigbee and with capacitive touch ones. I understand WiFi ones will be a problem if there are weak WiFi signal and there are limits to number of devices connected to wifi. I'm currently shortlisting this from Aliexpress
AVATTO
https://a.aliexpress.com/_msG7NkBMy ID not too familiar with smart home, so looks like I need to do this as a more middle term project. Don't think can finish all these by the time I move in to new place.
Many thanks for this! I was also looking at Aliexpress, comparing Aqara, Lonsonho & Avatto. Out of which, Avatto is the cheapest, hence I'm likely looking to get that (the rocker switch version):
https://a.aliexpress.com/_mrQtGLZ
Good to know that someone else is also looking at the same platform (Aliexpress) for purchase and eyeing the same brand!
Am still awaiting my ID for a quote on the electrical works.. Thanks for your info, gives me any idea how much it'd be... I'm looking at around 10 switch points, but each with different connection points (1 to 3 lights/points); would each switch point still be quoted as the same cost this way?
jikilan
If I rmb correctly, neutral cable is 1 whole loop in house, no matter how many switches on the point, it is still one cable to the neutral cable loop. So same charges.
cumzball
Hi just installed Tuya switches couple of weeks ago and having issues with lights turning on by itself randomly
It happens to only 2 of the switches while i do not face this issue with the other switches.
there is no schedule, timer or routines set up for these 2 switches. anyone can advice what can i do?
Switches are linked to google home/assistant
Switches are without neutral wire and using the capacitors that comes along with it
holy1god
wifi version or zigbee? wifi switches problematic, go for zigbee
I was looking at the zigbee hub from Avatto then I saw this:
https://www.aliexpress.com/item/400...earchweb0_0,searchweb201602_,searchweb201603_
Not sure if should get a wired hub or wireless hub. Since its all zigbee, can I assume that even though the hub and switches are different brands they should be able to connect?
mrwirus
my whole house using wifi tuya and sonoff switches. No issues at all.. Zigbee however has a small problem with the range in my home because they using the same 2.4ghz frequency.
So I prefer wifi more..
jikilan
make sure your ZigBee hub firmware is up to date. Good to check this too. Although not necessarily fix your issue
RyanJ
is there a good blog to follow on smart home automation in Singapore?
especially for smart lights, etc.
Neutral wire lighting circuits during reno or else look into options like a Lutron Aurora Smart Bulb Dimmer to over lay pre-existing switch.
Philips Hue up the house lights.
Either Google Home or Amazon Echo to connect to Hue Hub.
Alphas
There are recent tech on self-powered kinetic smart switches. The switch derived the energy when you press on the button and send the signal to the relay. Basically, there is no need for live nor neutral wires on the switch. It can link with google home, alexa via the tuya/smartlife app. I have another doorbell kinetic switch that do not need batteries, but now it can be used as a mains switches.
This kinetic switch is interesting, it also means the switch can be positioned anywhere without any cabling or wiring. I will be intending to have these switches with my next renovation.
Only require the relay at the electrical point of the device.
ccmheoa
hi guys,
ive installed some aqara d1 switches neutral (china) , now thinking of which hub i should buy.
should i use the aqara m2 hub global version? or xiaomi gateway v3 china
kun1he2
I have those with batteries. Didn’t know they have a new smart controller that can work with the battery-less switch. I may want to switch out all the RF/Wifi smart controllers for this. But, I worry about RF conflicts.
The RF is driving me nuts! Read a couple posts back. Turn on one switch meant for one light will trigger another light or two. And I have to bring out the ladder and reset one or two RF pairings.
Ah yes, I have a 3-gang RF switch which initially one of the switch started controlling one of my smart switches.
Then several weeks later, another one of the switch started controlling the same smart switch too.
Suspect somehow the frequencies generated are too close or starting to drift? Anyway, same as you, had to access the downlight in the ceiling to reprogram the smart switch - but decided not to use the same RF switch which was intended to control it - not sure if you get what i mean... :)
cosycatus
Hi gurus here
Can I ask for smart switches, what the best way to create a 2 way controlling system?
Eg light in the entrance foyer, can be switched in when just come in thru the door, then reach living room can use another switch to off?
Would RF switch do the trick? Is it stable?
v1hypersg
anyone know how can i integrated all my devices under 1 platform
I have the following :
TP link smart plugs
Eufy video door bell
Eufy motion sensor
Eufy entrance sensor
Eufy pan and tilt camera
jikilan
Hi gurus here
Allow me to share a different opinion. I was in the same situation when converting to smart switches from existing setup. Then I went for voice command for all the switches. It became not an issue anymore since not going to press it... But this is only for my case.
If using smartlife, you can set the automation to sync the on/off status between 2 switches. And provided you have asked your technician to connect the cables for this 2 smart switches.
holy1god
TP link smart plugs
Eufy motion sensor
i think the only option will be using raspberry pi 4 + home assistant
