Check the installation and do a reset by holding the button.bought tuya switches. out of 9, 5 works only. gotten electrician to install.
and now, none of it can connect to router. what is the issue here?
Use this as reference
yesIntend to purchase an international m2 hub from lazada. Can the hub works with d1 switches from Taobao or shopee?
Yes it does. I made a mistake in purchasing M1s hub from shopee and end up its region lock to PRC.Intend to purchase an international m2 hub from lazada. Can the hub works with d1 switches from Taobao or shopee?
Is your M1s hub region lock to PRC? Mine is and I have to buy M2 from a local shop to replace it.Anyone tried to use aqara M1S hub and couldn’t bind using aqara app?
I tried Mi home app and it can connect but cannot add aqara D1 switches in google home. So I have to use aqara app instead because I want to use google home for its voice command.
I followed aqara app instructions like 2.4ghz, strong signal, normal characters for wifi password. But still can’t bind the hub.
Anyone has same experience and managed to solve it?
I have just move to my first own place and finish setting up the basic smart devices. Only manage to configure 4 scene / routine.
Uses Aqara D1 with M2 hub, combination of broadlink IR and RF device to control standing fan, Aircon, TV, Soundbar, xiaomi robot
Waiting for another 3 motion sensor to bring the automation up another level as I don't want to be talking to Google all the time. Some time, I just want it to work like when I enter bathroom at night, the light will just turn on, and off after some inactivity.
Aircon wise, broadlink can switch on when binded to GH but I have not figure out if I can set timer.
One meh thing is that the broadlink is unable to detect my Crestar Value 5 Blade ceiling fan, spent some time there and one Google search result states that the manufacturer may not use the same RF chip for the same model, hence it may not work. Anyone can advise how to find out the exact RF channel the fan is using? I checked with Crestar before buying that the RF channel is 433 which is in line with the Broadlink spec but doesn't work.
EDiT: Credit to Alex (EvilBear?) for your video. It helps a lot though I am a early adopter of GH and smart plug.
But If you want to unlock its full potential, a cloud subscription called Nest Aware is required, and not cheap too. Personally, I will stick to Ring Doorbellhttps://blog.google/products/google-nest/new-google-nest-latest-cams-and-doorbells-are-here/
The new Google Nest Doorbell looks pretty good. Cheaper than their current Nest Hello doorbell and is battery powered, so there's no need to think about how to wire it up. Unfortunately, it doesn't seem to be available via Google SG.
Hi @swanage18Hi,
I am new to home automation and read through many comments in this thread but still as confused. Maybe some kind souls can help?
I assume that aqara is still the preferred option and this is compatible to google home?
Of course - there are 3rd party providers for that - e.g Home @uto. It will cost more thoughI am looking to connect lights, aircon and curtains. Is there a one stop solution where I can purchase everything, or should I get everything online?
There are many other switches that you can get besides Aqara - the Tuya switches are gaining traction here in this thread too.For lighting, I assume that I just need to get aqara switches?
For aircon - you just need a IR blaster only - no need for M2Also for aircon, do I need an M2 hub in each room, or can I just get an M2 hub and IR blasters for each room?
Curtain motor/ tracks from Taobao or online is alrite. There are contractor in Carousell that does smart curtains - you can check them out.For curtains, does anyone has experience buying the track from taobao or is there a reliable contractor in Singapore who can do the job at a reasonable fee?
For Aqara if you get the international version (and connected to their OTHERS server) - response time will be better. For Mi Home to function well - you'll have to connect to their China server which will be quite laggy.Also the app that I should use is Aqara or Mi Home? What is the difference?
Many thanks.
Thank you batniss - was still contemplating between aqara versus tuya ecosystem.i have both but i prefer Tuya over Aqara. - i use a lot of wall switches. Wife prefer touch over rocker so one major reason why we dump Aqara away
easier to set up, no need gateway. Straightforward and works reliably. However, wifi motion sensor has 2-3s lag. If it matters.
This is nice but I dont need because i will be using my phone.Thank you batniss - was still contemplating between aqara versus tuya ecosystem.
are you still using any aqara devices currently? Is there any you cant live without (which Tuya doesnt have)?
feel that aqara has a wider ecosystem of products to choose& buy from e.g. the aqara single control panel i'm looking at - tuya doesnt have it (https://detail.tmall.com/item.htm?spm=a1z0d.6639537.1997196601.711.77c77484pBb2ey&id=630801438842)
Actually tuya have, iam using the global version.Thank you batniss - was still contemplating between aqara versus tuya ecosystem.
Not cheapActually tuya have, iam using the global version.
https://ibb.co/R6pVm0W
